Old 10-20-2018, 09:36 AM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
opening 2017 brz foglight assembly
So i have a 2017 and know that the fog lights are an all in 1 assembly. Is there any way i can open this up and replace the bulb with something that is brighter and has a wider beam? now that it is getting darker earlier i forgot how trash the fog lights are vs my tdi in seeing the sides of back roads. it looks like im going to have to replace the whole thing, but then the issue is the 3 screw mounting and it looks like the 13-16 options are 4 screws
Breadman is offline   Reply With Quote
Old 10-20-2018, 04:25 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Bulbs do not affect pattern. (Same for same)
The lens and reflector in the housing do that.
Go LED bulb maybe.
Old 10-20-2018, 04:44 PM   #3
Breadman
Breadman's Avatar
Go LED bulb maybe.
cool now how do you do that when it is 1 unit and you cant remove the bulbs, which was my original point...
Old 10-20-2018, 05:00 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Just do it properly and buy replacement housings. You won't get a proper beam pattern any other way that won't also blind oncoming traffic. Check out my post:
http://www.ft86club.com/forums/showthread.php?t=114241
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 10-20-2018, 05:31 PM   #5
ShansBRZ
Drives: 2017 brz
The 2017 is led already. Maybe you need to raise them up some? Mine are plenty bright and wider than the headlights already.
ShansBRZ is offline   Reply With Quote
Old 10-20-2018, 05:44 PM   #6
Breadman
Breadman's Avatar
that isnt a 2017, they have a different bolt pattern and a differ bezel.
Old 10-20-2018, 05:52 PM   #7
x808drifter
LMGTFY
Just realized that you already have LED.
Like shans said, maybe just need to aim them, other than that only other option would be to replace the lights themselves.
If they are LED I don't think there may be a way to replace the LED's in the factory housing with better ones.
Old 10-20-2018, 06:04 PM   #8
Breadman
Breadman's Avatar
i think im going to test to make sure they are aimed correctly tonight with a friend. ive thought about getting a 4 bolt (the old style) and zip tieing them in or making a new bracket out of sheet metal. i feel like they are aimed too far in the center or maybe my headlights are just aimed too low and im not seeing them
Old 10-20-2018, 07:13 PM   #9
ShansBRZ
Drives: 2017 brz
Mine were aimed low from the dealer. I raised them up some and it’s made a difference. It is a pain to get to the adjuster though.
Old 10-20-2018, 07:40 PM   #10
Stang70Fastback
A.K.A. Starlord
Oh crap. Completely missed the 2017 part. My bad, lol.
Old 10-21-2018, 09:35 AM   #11
Breadman
Breadman's Avatar
i aimed mine at the garage last night and they were aimed into the ground about 3 feet infront of the hood. do you have how they should be?
Old 10-21-2018, 08:13 PM   #12
ShansBRZ
Drives: 2017 brz
Not sure what the official aiming should be but I have mine almost level or straight out.
Old 10-22-2018, 04:49 PM   #13
x808drifter
LMGTFY
My go to is measure how much lower they are to the headlights and aim them that amount lower.
Old 10-22-2018, 05:12 PM   #14
Stang70Fastback
A.K.A. Starlord
The LED ones I have in my 2015 I aimed by ensuring that the cutoff height was just a bit lower than the actual height, so that I knew they were aimed slightly down. I drive with them on whenever my headlights are on, and have NEVER been flashed by anyone.
Max throttle opening... Uplink Software Tuning 3 02-10-2017 11:07 PM
Need Help Opening Taillights in PDX XanRules Northwest 7 10-07-2015 05:07 PM
Opening in GTA group buy Sport-Tech CANADA 6 05-23-2012 11:17 PM
