Old 01-06-2021, 07:42 PM   #1
JIM THEO
Drives: BRZ 2018
Percentage of port injection and carbon build up
Most of the known and accredited professional mappers for our platform reduce the amount of port injection below 20-30% and this available only at high rpms, and I wonder, why no-one complains for carbon build up on valves and injectors while most refuse to use fuel/injector cleaners?
When I changed my intake hose with a silicone one I saw carbon deposits after the throttle butterfly, and as I think my millage went up slightly, I'll use before my next oil change some intake cleaner along with a good polyetheramine fuel/injector cleaner (35.000km car)
But it seems I am the exception, not the rule, have I miss something?
JIM THEO is offline   Reply With Quote
Old 01-07-2021, 06:02 AM   #2
steve99
Correct most tuners especiaply on petrol and lower octane petrol will run less port injection than standard tune especially at high loads high rpm.
It likely not a big problem for deposits if you still running 30 or 40% port at lower rpm lower load where most driving is done and most deposits form.
Cars driven at high speeds and loads likely get less deposits anyway.
The 2017 and later cars ran avout 30% port at high spped/loads where the earlier cars ran zero to 20%. So there may have been a reason for that change but may have been emissions related.
The depisits or carbon you see in the throttke body are more likely due to OCV carankcase gasses or the EGR done via the strange values in the stock intake cam tables round 2000 rpm.
For that yoy likly need upper cylinder engine cleaner sprayed into intake as per subaru recomendation every 6 months.
Fuel additives might help with injectors in places where fuel quality is low.
I use the upper cylinder cleaner but i never get any noticable smoke out exhaust
however i do ise 30% port at high rpm and loads in my tune and im on ethanol E85 fuel which burns very clean (. 7 years no issues)
The Following 3 Users Say Thank You to steve99 For This Useful Post:
JIM THEO (01-07-2021), SCFD (01-09-2021), Thefalls (01-07-2021)
Old 01-07-2021, 08:21 AM   #3
Ohio Enthusiast
Drives: 2018 BRZ
First time I've heard of that. Is this in the recommended services table? Do you have a reference for this?
Ohio Enthusiast is online now   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
SCFD (01-09-2021), Wally86 (01-07-2021)
Old 01-07-2021, 09:16 AM   #4
tomm.brz
Drives: brz 2017 hksv2
For american fuel (both 93oct and E85) which are very good, i like to keep higher port% at high rpm too
because the engine will take higher ignition timing anyway because of the better fuel
For shittier euro fuel, for example our italian E5 100ron fuel which is much worse than 93oct us fuel i like to use a lot less port% and more DI
i also think like steve the soot you see it s mainly caused by EGR and intake reversion
it happens also to centrifugal supercharged car, if you keep high overlap on vacuum zones like it was NA
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
JIM THEO (01-07-2021), RToyo86 (01-07-2021)
Old 01-07-2021, 09:54 AM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Wouldn’t a good catch can system eliminate all of this?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-07-2021, 10:00 AM   #6
tomm.brz
it s intake reversion, it comes back from the intake valves to manifold to intake hose when there is overlap and vacuum on intake
Old 01-07-2021, 12:12 PM   #7
JIM THEO
Drives: BRZ 2018
My manual states clearly "Add injector cleaner every 15.000kms" and I am using "Mannol intake valve cleaner" which has similar composition with Subaru upper engine / top engine cleaner, and HKS DDR which is 100% hyper polyetheramine like (Japanese) "Subaru PEA carbon cleaner":
The Following 3 Users Say Thank You to JIM THEO For This Useful Post:
callisto (10-12-2025), Ohio Enthusiast (01-07-2021), steve99 (01-08-2021)
Old 01-07-2021, 12:24 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had my engine out at 70+ thousand miles and noticed no more intake buildup then any other engine
Old 01-07-2021, 04:53 PM   #9
ls1ac
ls1ac's Avatar
The throttle body is nowhere near the valves. the only way to get buildup is backfire or dirty oil back through the system.
Old 01-08-2021, 03:59 AM   #10
steve99
see JIM s post above
here is the subaru product
https://parts.citysubaru.com.au/prod...-cleaner-sa459
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 06:17 PM
Port injection only possible? solidsnake11 Software Tuning 22 01-10-2020 12:21 AM
Is Port Injection more important when boosted? KoolBRZ Software Tuning 24 03-17-2016 03:25 AM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 05:53 PM
