Old 12-21-2019, 03:08 PM   #1
solidsnake11
Drives: brz
Port injection only possible?
c
solidsnake11 is offline   Reply With Quote
Old 12-21-2019, 03:10 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Short answer: *snaps finger* Yes
Long answer: would require a complete retune on the ECU, i could see this if you went custom turbo and decided for simplicity to run the port injection and not DFI, make some plugs, throw on bigger injectors and send.
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
solidsnake11 (12-21-2019)
Old 12-21-2019, 03:22 PM   #3
tomm.brz
Drives: brz 2017 hksv2
Put 100% in every cell on the 3 tables of PI/DI ratio and you have only PI working
May I ask why?
The Following User Says Thank You to tomm.brz For This Useful Post:
Old 12-21-2019, 05:15 PM   #4
kev0
Drives: '14
Are there any downsides to running PI 100% of the time?
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
Old 12-21-2019, 05:43 PM   #5
steve99
Yes id be reasnobly sure the DI injectors would get damaged likely due heat if you turn them off using the pi\di tables in tune. In standard tunes your always running fuel through the DI system and i suspect without that the di injectors in the compustion chamber will get damaged without the fuel to cool them.
The stock port injectors are quite small 228 cc and dont have the capacity to run even an NA engine at high rpm full load without di., So you would need bigger ports even on NA car to run without DI.
So id say dont try to run full port unless your prepared to toast a set of DI injectors
Old 12-21-2019, 05:49 PM   #6
steve99
If your talking about completly removing the DI system ie the DI computer on side of engine and DI pump, thats going to introduce a bunch of other issues with ghe ecu not seeing those monitors componemts, its likey going to go into limp mode or at least get very confused. To remove that stuff your likely going to need to re write ecu code, i suspect simply disabling dtc codes wont work even if all the codes defined .
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Clutch Dog (12-22-2019), solidsnake11 (12-21-2019)
Old 12-21-2019, 06:31 PM   #7
tomm.brz
Never tried, but with ecutek you also have "fuel quantity DI" and "Fuel quantity PI" as available custom inputs so you have the possibility to control those with a multiplier for example
About using low pressure PFI injector with the GDI wiring.. No idea, the GDI scaling and gestion is extremely complicated, since it works with the variable high pressure
Old 12-21-2019, 06:59 PM   #8
tomm.brz
Originally Posted by solidsnake11 View Post
Papadakis Racing melted the end off a direct injector on the supra.
yes well he was also trying to put out 1000hp with 40 psi
i did a release in my car with 100% PFI to calibrate it to the GDI and did a pull and nothing bad happened
Old 12-22-2019, 12:38 AM   #9
Clutch Dog
nothing happened that one time. but all it takes is for the DFI injectors to overheat the tips and bam zoom new motor.
this is one of those things you do it right, or do it twice
tomm.brz (12-22-2019)
Old 12-23-2019, 02:51 PM   #10
ka-t_240
Papadakis didn't hurt anything, it just blew molten steel out the turbo.
In case you missed the reasoning for me to cut off direct injection. I am going to replace my engine with a k24 honda inline 4 and I am going to retrofit the fa20 fuel injection on to it.
Are you going to try and run a Honda K24 completely using FA20 engine harness/ECU?
If you are not going to control the k24 via a FA20 ecu, then there is no issue to worry about here.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
solidsnake11 (12-23-2019)
Old 12-23-2019, 03:36 PM   #11
Clutch Dog
Yes I am going to try
does the firing order match? or are you wanting to change the plugs out for whatever fires on what.
fuel rail can be whatever, but id be looking into how the engine sees itself with cam angle sensor and throttle position..
an interesting proposition.
if there was a good K24 swap kit, and you did all the hard work you could snuff out the S14 craze these days with the k24..
hell id put one ine..
currently trying to get funds for a rx8 swap ren into an brz
Old 12-23-2019, 06:53 PM   #12
tomm.brz
I'm using A01C RR.
frsport has not sent me my ecutek?
So things I have learned.
The fuel pressure sensor has to be hooked up(no start). It reads around 52psi with out the fuel pump solinoid plugged in. Hey who doesn't love to know their fuel pressure.
I can get it to run without codes.
My engine is still running on direct at idle?
Anywhere above idle is port inj ?
I may have to run 8 injectors. The intake that pure uses has provisions for 8.
Things are looking promising.
what i know for sure, and think you xan t change, is: car start 50% PI 50% DI
then goes after a few to 100% PI
then goes to what ratio table is
maybe forcing 100% PI with custom maps work but can't tell you
Old 12-24-2019, 11:40 AM   #13
sato
sato's Avatar
Drives: Dodge Patitas
If I remember correctly, they just removed the direct injectors and plugged them holes with a solid piece of metal.
Anyway, good luck with your build. Loving your experiments!
Old 01-03-2020, 07:30 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
K24 head gasket
That's all you really need.
solidsnake11 (01-03-2020)
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 06:17 PM
Is Port Injection more important when boosted? KoolBRZ Software Tuning 24 03-17-2016 03:25 AM
Best e85 oil/ meth injection Fastbrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-26-2014 03:28 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 02:17 AM
