Old 12-28-2020, 10:55 AM   #1
norcalpb
norcalpb's Avatar
Really bad brake shaking.
Hello all,
My last 2 track days I’ve been getting some serious vibration from the brake pedal once the brakes get hot. The shaking only seems to be coming from the front.
I have DTC-30, centric rotors, and dot 4 fluid.
After my first day of shaking I replaced all 4 rotors and swapped fluid afterwards but the shaking is still there starting on like the 3rd lap. The first 2 laps I can slam on the brakes and it’s super smooth coming to a stop.
Does anyone know what this could be?
TIA
Steve
Old 12-28-2020, 11:04 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Take the first set of rotors and see if they are still true.
Old 12-28-2020, 11:33 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Can you post of pic of your rotors? My car would do this with XP10's. It would develop so much pad deposit it would shudder hard under braking.
Here is what mine looked like.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
strat61caster (12-28-2020)
Old 12-28-2020, 11:36 AM   #4
norcalpb
norcalpb's Avatar
Unfortunately I threw them away last month. They weren’t true, I could feel waves on the rotor face without even pushing that hard. At Laguna Seca I would get them so hot they almost seemed to temporarily straighten up and the shaking would stop.
I’m thinking my pads are worn in the same manner my old rotors were, and I just need to go crazy on a future brake bedding session? I’ve done one minor bedding session, but haven’t gone any harder than that as I don’t want to catch California on fire with sparks/lack of rain.
Old 12-28-2020, 11:40 AM   #5
norcalpb
norcalpb's Avatar
Yeah they don’t look good lol. One track day and like 2k street miles on these. Is 2021 the year I finally cough up the $ for a BBK??
Old 12-28-2020, 11:45 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Looks like the pad smeared on the rotor. Rebedding them should make it go away, always worked for me. You may need to add ducting in the future or go to a more robust pad.
norcalpb (12-28-2020)
Old 12-28-2020, 11:54 AM   #7
norcalpb
norcalpb's Avatar
Yes I agree about adding a more robust pad. I should have went with DTC-60, but I must say the DTC-30 is quite usable on the street which is mainly what I use my BRZ for.
I have Rooducts brake ducts which are similar to the GT3 ducts, but do you think something like the Verus ducts would be worth going to before upgrading to a bbk?
Old 12-28-2020, 12:00 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am not familiar with Hawk pads, if the 30 is a mild pad that is probably mostly the problem. Most street/track hybrid pads just don't hold up once you get faster on a good tire. I am not super familiar with the effects of different brake ducts since I have never run them, I went BBK pretty early in on my tracking adventure.
Old 12-28-2020, 12:21 PM   #9
norcalpb
norcalpb's Avatar
What is strange is that I have used less intense pads than the DTC-30 on the track (EBC Yellowstuff and Carbotech AX6) and there was no shaking but a poisonous-like metal burning smell that could be smelled by the people behind me. Brakes have been the hardest thing for me to learn in terms of tracking.
I'll re-bed the brakes and post pictures of the rotors soon.
Old 12-28-2020, 12:50 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The PMU HC800's I first ran would behave like that. They would smell but never deposited material on the rotors. They would just only last 4 days.
Old 12-28-2020, 01:16 PM   #11
strat61caster
strat61caster's Avatar
+1 smeared pad deposits
always heard mixed reviews about Hawk so I've stayed away from the brand
ineedyourdiddly
Old 12-28-2020, 02:26 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pretty sure you're braking so hard that you're stopping the earth's rotation, hence the strange feeling. All is well, just maybe lighten up on the pedal a smidgen.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
churchx (12-28-2020), norcalpb (12-28-2020)
Old 12-28-2020, 03:08 PM   #13
norcalpb
norcalpb's Avatar
Lol yes when they are in “shake mode” luckily I can brake lighter and earlier and still get through the day.
Old 12-29-2020, 11:02 PM   #14
jflogerzi
jflogerzi's Avatar
Get 2 sets of pads. 1 for street and 1 for track. Talk to Mike at CSG. If you can get 2 sets of rotors as well as blanks are cheap and just swap before track days. It's a pita but might save you from going to a bbk
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (12-30-2020), norcalpb (12-31-2020)
New Clutch Shaking Going Into 1st?!? Jozy Engine, Exhaust, Transmission 6 12-15-2020 03:31 AM
Rear shaking brzboy Engine, Exhaust, Transmission 16 06-11-2019 09:56 AM
Brz rear shaking brzboy Engine, Exhaust, Transmission 6 06-10-2019 10:38 PM
scion frs 16 shaking. help! Kana Issues | Warranty | Recalls / TSB 20 10-16-2016 03:23 PM
shaking of car Adam86 AFRICA 3 05-17-2013 08:42 AM
