12-24-2020, 01:56 PM | #1 |
Drives: orange car
4g63 Swap
Hello gents,
So I was set on K24 turbo swap with bmw f80 dct transmission. Now my shop called me and said they were having a talk and came up with the idea of putting evo 9 engine in. They have freshly built stroked 4g63 engine that will probably run on motec ecu. They said they need to figure out a bunch of things along with the transmission but they are highly capable and i don't have any doubts about them building my car but I figured that I will do my part and check in the community for any thoughts, advice on transmission, etc.. Have a nice hollidays and stay safe 👍 |
12-24-2020, 02:56 PM | #2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | RIĐO (12-24-2020) |
12-24-2020, 03:18 PM | #3 |
Drives: orange car
I was considering s2k trans but I think we will try with bmw first. People might get offended since its auto
12-24-2020, 03:27 PM | #4 |
Rust bucket enthusiast
Good luck. That engine really doesn't swap well, it's facing the wrong way. K24 is a far better choice from every angle possible. I love the 4g63 but please
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following User Says Thank You to DarkPira7e For This Useful Post: | wparsons (01-30-2021) |
12-24-2020, 03:35 PM | #5 |
The Following 3 Users Say Thank You to Ashikabi For This Useful Post: |
12-24-2020, 03:47 PM | #6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Ah yes, a modern rendition of the Mitsubishi Eclipse GS-T/GSX. Proceed.
The Following 2 Users Say Thank You to weederr33 For This Useful Post: | ninjan00dles (02-04-2021), RIĐO (12-26-2020) |
12-24-2020, 03:47 PM | #7 |
Fair enough!
The Following User Says Thank You to DarkPira7e For This Useful Post: | RIĐO (12-24-2020) |
12-24-2020, 03:55 PM | #9 |
Drives: orange car
mid engine awd 86 sounds mental
01-20-2021, 07:15 PM | #10 |
Drives: 2016 Subaru BRZ
You couldn't pay me to swap in a 4G63. One timing belt snapping on the interstate was enough for me to swear off Mitsubishi.
01-26-2021, 06:00 AM | #11 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
It wasn't the broken exhaust studs, stripped coolant necks, seized turbo studs, broken transfer cases, walking cranks, or yearly $5,000 transmissions?
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
01-30-2021, 09:29 AM | #12 | |
Why are they suggesting such a downgrade? A K24 is a better engine in every way. There's also well known ways to have it be reliable in a RWD configuration even under heavy track use. Why the BMW transmission? This sounds like a hugely expensive idea. If you're after big power and a gearbox to handle it, why not look at an LS swap with matching gearbox?
01-30-2021, 02:27 PM | #13 | |
Drives: 2013 Ultramarine FR-S
02-04-2021, 11:53 AM | #14 | |
I was questioning why the specific BMW one, and not another option.
Similar Threads | ||||
FRS 4.8 LS swap | kurty85 | Engine Swaps | 207 | 03-03-2023 12:48 PM |
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
