Old 12-24-2020, 01:56 PM   #1
RIĐO
RIĐO's Avatar
Drives: orange car
4g63 Swap
Hello gents,
So I was set on K24 turbo swap with bmw f80 dct transmission. Now my shop called me and said they were having a talk and came up with the idea of putting evo 9 engine in.
They have freshly built stroked 4g63 engine that will probably run on motec ecu. They said they need to figure out a bunch of things along with the transmission but they are highly capable and i don't have any doubts about them building my car but I figured that I will do my part and check in the community for any thoughts, advice on transmission, etc..
Have a nice hollidays and stay safe 👍
RIĐO is offline   Reply With Quote
The Following 2 Users Say Thank You to RIĐO For This Useful Post:
DustinS (01-30-2021), Joveen (12-24-2020)
Old 12-24-2020, 02:56 PM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by RIĐO View Post
Hello gents,
Adapt it to work with Z or S2k transmission. Or full send it and put the motor in the back. Then you could AWD "easily"
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
RIĐO (12-24-2020)
Old 12-24-2020, 03:18 PM   #3
RIĐO
RIĐO's Avatar
Drives: orange car
I was considering s2k trans but I think we will try with bmw first. People might get offended since its auto ��
Old 12-24-2020, 03:27 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Good luck. That engine really doesn't swap well, it's facing the wrong way. K24 is a far better choice from every angle possible. I love the 4g63 but please
wparsons (01-30-2021)
Old 12-24-2020, 03:35 PM   #5
Ashikabi
Ashikabi's Avatar
It's only facing the wrong way until you turn it
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
DustinS (01-02-2021), ninjan00dles (02-04-2021), RIĐO (12-24-2020)
Old 12-24-2020, 03:47 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ah yes, a modern rendition of the Mitsubishi Eclipse GS-T/GSX. Proceed.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
ninjan00dles (02-04-2021), RIĐO (12-26-2020)
Old 12-24-2020, 03:47 PM   #7
DarkPira7e
DarkPira7e's Avatar
Fair enough!
RIĐO (12-24-2020)
Old 12-24-2020, 03:49 PM   #8
Ashikabi
Ashikabi's Avatar
Fair enough!
If he turns or 180 and puts it in the back seat he can have AWD
RIĐO (12-24-2020)
Old 12-24-2020, 03:55 PM   #9
RIĐO
RIĐO's Avatar
Drives: orange car
mid engine awd 86 sounds mental
Old 01-20-2021, 07:15 PM   #10
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
You couldn't pay me to swap in a 4G63. One timing belt snapping on the interstate was enough for me to swear off Mitsubishi.
Trueweltall is offline   Reply With Quote
Old 01-26-2021, 06:00 AM   #11
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
It wasn't the broken exhaust studs, stripped coolant necks, seized turbo studs, broken transfer cases, walking cranks, or yearly $5,000 transmissions?
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
ninjan00dles (02-04-2021), Wally86 (02-04-2021), wparsons (01-30-2021)
Old 01-30-2021, 09:29 AM   #12
wparsons
wparsons's Avatar
Hello gents,
Why are they suggesting such a downgrade? A K24 is a better engine in every way. There's also well known ways to have it be reliable in a RWD configuration even under heavy track use.
Why the BMW transmission?
This sounds like a hugely expensive idea.
If you're after big power and a gearbox to handle it, why not look at an LS swap with matching gearbox?
flickr
Old 01-30-2021, 02:27 PM   #13
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
DCT swaps are the new thing right now. Though in the very VERY early stages. Still no real base maps available and little documentation, but they are extremely capable and offer just about the best experience. Manual when you want it, with fast shifts and no torque loss, while also being able to be put in to Auto mode and drive around. It's why I ditched my T56 magnum for one.
Old 02-04-2021, 11:53 AM   #14
wparsons
wparsons's Avatar
I was questioning why the specific BMW one, and not another option.
flickr
FRS 4.8 LS swap kurty85 Engine Swaps 207 03-03-2023 12:48 PM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
