Old 12-13-2020, 10:42 AM   #1
gpvecchi
gpvecchi's Avatar
HKS Hipermax IV GT Spec 20 review
I drove my car a couple of days after fitting this coilover kit, and these are my first impressions.
I come from PP Sachs dampers with JDM STi springs; the kit has been fitted with shipped F16/R17 mm lowering and 15/30 click setting; front camber was set at -1.5 degrees.
Hydraulic is wonderful, comfort is the same of stock suspensions, or a little more, as this is not as harsh as Sachs, rough roads are silky smooth but there is no buncing.
Car is very flat, a little too much for my tastes, perhaps 4kg/mm springs would be better. Much more traction, less oversteer (finally!), drift is much more controllable.
Camber plates are useless, 1.5 is almost maxed out, and they transmit big bangs on the chassis when hitting big potholes. Very annoying to adjust. But this is not specific to this kit.
The only doubt I have is the front excursion, that is declared as 87 mm.
This should be good, but I think I bottomed out a couple of times...
gpvecchi is offline   Reply With Quote
Old 12-14-2020, 02:58 AM   #2
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Thanks for the review.
Do you feel the coils are tuned on the softer side with comfort in mind?
Maybe you could try going stiffer on the fronts.
The spoiler is the front camber plates, really that noisy?
Can they be switched to something else?
Thefalls is offline   Reply With Quote
Old 12-14-2020, 03:43 AM   #3
JIM THEO
Drives: BRZ 2018
Interesting that you went from a factory suspension to a quite lowered coilover, although they said it's "Ultimate Street Damper" they mean for the Japanese perfect roads!
Before the tS MY18 suspension I have now, I fitted for a while Ohlins coilover and while it had fantastic damping, due to reduced rear suspension travel and our uneven roads it bottomed out quite often.
Bear in mind our suspension has limited travel, if I remember right 2,5" bump-3,5" rebound, so for road use max lowering at least for our imperfect roads is not more than 1 cm!
JIM THEO is offline   Reply With Quote
HKS Hipermax IV GT coilover review Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-05-2022 02:12 PM
New HKS Hipermax IV SP Coilover Review By Evasive Motorsports Evasive Motorsports Brakes, Suspension, Chassis 132 03-22-2017 07:00 PM
Review: Spec D Exhaust mattaubel Engine, Exhaust, Transmission 11 07-17-2016 06:02 AM
My Spec D headlight review Gixxersixxerman Cosmetic Modification (Interior/Exterior/Lighting) 7 10-07-2014 06:31 PM
Preview/Review - HKS Hipermax IV GT Coilovers - Just Tested! Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-04-2014 07:28 PM
