Old 04-15-2014, 05:04 AM   #1
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
My Spec D headlight review
So I was able to get my hands on a set today. I've been asked to give my honest review of them. Pros and Cons.
I'll start with the easiest.. Pros
They fit the car...
And...
Well they fit the car..
They are not a horrible light, but the projector is crap. They through a H1 bulb in there with spacers/adapters in a slot that fits a D2S OEM style bulb perfect. If you install a hid bulb you have to use another washer to hold it in. This is crap because you have to play with the bulb for ever to get any kind of "proper" light, and I use proper loosely..
The "DRL" strip looks good in low lighting, but put it in the sun and it's washed away. You can still see it glowing a little, there is a difference between on and off in direct sun. But it's not much and from a distance you wouldn't be able to tell..
They are heavy.. About as heavy as the OEM JDM/10 series/monogram setup, with ballast and all.
They are molded to run OEM ballast bolted to the bottom and again OEM D2S bulbs so that's a positive, but even then it's not the best cut off.. Better then the H1. Finish looks very good. Plastic lens feels very cheap. And you can easily see "leaks" of lights around the strip.. I can actually see between the light defuser and housing to the led chips. There is no "DRL" function, but that's remedy by tapping it into the high beam positive wire. A DRL mod would work for this. Same way for the winjets that @fteightysix sells. I personally liked the blinkers, though as being led the viewing angle is pretty much directly in front.
Here are some pictures
Bottom of the housing again set up to run OEM ballast should you choose
H1 stock bulb that comes installed in it
Morimoto D2S XB35 bulb is a direct fit..
Cutoff with the D2S isn't nothing to be proud of, but I think is better the OEM... Maybe
Set up with the customers HID H1 kit
And after a few minutes moving the bulb all over I finally got this
I think with a proper retrofit, running OEM parts, it would be a decent setup.. I'd like to see how the lens stands up, but otherwise it's ok.. I'd personally change out the led chips to something better also.. That may help with the light being so washed out in the sun..
Overall I'll rank the winjets far above these as far as fit and finish and quality.. Looks well I like the looks and if that's what your going for, in lower light conditions I think you'll be happy.. But that's about all this light could do for me..
Gixxersixxerman is offline   Reply With Quote
Old 04-15-2014, 05:38 AM   #2
FRSHunter
Drives: Asphalt FRS
How does the OEM ballast connect though? Theres usually a hole that connects the power to the bottom of the ballast
FRSHunter is offline   Reply With Quote
Old 04-15-2014, 07:36 AM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
@Gixxersixxerman @fteightysix this is very sad. I have Winjets and don't want to take a step back in terms of light output. Any chance that the set you received could have "defective" parts and manufacturing?
I want to like this headlamp.
You mentioned that there was no DRL function. How would one go about having the LED strip function as a DRL?
Can you post more pics of the headlamp showing more than the cutoff? How it looks installed on the customer's car and the LED strip + HIDs?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 04-15-2014, 12:50 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
oh my god. I was holding these lights in such high hopes
Im no electrical engineer so pulling these apart and rewiring them to work better isnt going to be my forté. Looks like the stock BRZ lights are still the best.
Old 04-15-2014, 01:10 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
So… what does the front look like?
Old 04-15-2014, 01:35 PM   #6
Gixxersixxerman
That's just a rubber cap, once removed it's already got the cut out for the power wire to the bulb and all
It may have very well be a defective model. When we called Spec D, they told us that some of our order couldn't ship because "half the lights out there have a defect" but mainly bad LEDs from my understanding.. You can easily wire it to make it function as a DRL. Just splice the wire into the positive wire of the high beam. It's live when your driving as the OEM setup that's the DRL..
I personally didn't take pictures of anything else, but I'll post a link.. This might be what people are looking for and I tried to come up with as many positives as I could.. With some work I'm sure these can be a great piece.. Better projector, or maybe even some work on this one, I'm unsure, and some bright led chips.. And you have some better lighting going on here.. My job is centered around lighting, and for me this wouldn't cut it, but maybe that's fine for others, most seem to think the hid in OEM projectors is just fine
Here is a link, the customer loved it.. And in the end he spent his money and liked it, so that's all that matters I guess
http://www.ft86club.com/forums/showthread.php?t=63402
Old 04-15-2014, 06:18 PM   #7
randomweather
Drives: FRS
Is the LED strip closer to 6k or 8k? What color HID would match it?
Some pics are more purple-ish, while some are more blue-ish...
randomweather is offline   Reply With Quote
Old 10-07-2014, 06:31 PM   #8
DJEQ1988
Drives: Red Fr-s
spec-d hid kit
Hey can you show me how to install the h1 bulb kit, saw the picture you have but don't understand what's going to what wire.
DJEQ1988 is offline   Reply With Quote
*****Official Spec-D headlight groupbuy 86SPEED Groupbuys 197 11-28-2015 12:48 AM
Winjet Headlight Owner Review JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 10 10-13-2015 01:14 AM
Genuine Toyota 86 LED + HID Headlight $599.99 *IN STOCK* nigel-jdmparts Exterior Parts - Lighting 27 05-14-2014 01:36 PM
AutomationLED LED Headlight Bulbs Review Squishy86 Cosmetic Modification (Interior/Exterior/Lighting) 7 03-31-2013 12:40 PM
AutomationLED LED Headlight Bulbs Review Squishy86 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-18-2013 06:44 PM
