Drives: 2013 Gt86
Wheel bearing issue?
Hi,
I have an issue on the front left wheel area when on highway speeds. When im cruising at around 100km/h i hear a slow but loud pulsing/vibration noise. When i press the accelerator petal it goes away, only when im not on the gas the noise comes up. I have brand new tires at the front so i doubt its uneven tire wear, the only thing i could suspect is the wheel bearing. Could anyone confirm that this is a symptom of a faulty wheel bearing? Does anyone have any other suggestions on what i could be? Thanks
Jack up the front of the car and shake the wheel side to side to see if there is any play.
Since you have a 2013, they could be coming due anyways. |
| Another throw-out bearing issue | chipmunk | Engine, Exhaust, Transmission | 68 | 09-17-2019 11:22 AM |
| Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 08:49 PM |
| Noisy Wheel Bearing | AndyBRZ | Tracking / Autocross / HPDE / Drifting | 6 | 09-25-2017 07:36 PM |
| clutch bearing issue | jeffsfrs | Issues | Warranty | Recalls / TSB | 5 | 10-18-2016 12:24 PM |
| Wheel bearing? | Nylander | Issues | Warranty | Recalls / TSB | 20 | 06-08-2015 04:57 PM |
