Old 11-21-2020, 12:00 PM   #1
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Spoiler / wickerbill
Well, I believe I've come to the point in my tracking adventure that I am researching aero: adding a splitter and spoiler (not a wing) and maybe rear diffuser.
Looking for others'experiences, recommendations, warnings, etc.
Planning on making the splitter.
Looking for a spoiler just large enough to be able to add an adjustable strip to it's rear surface.
MY14 BRZ
Sent from my moto g power using Tapatalk
snuff58 is offline   Reply With Quote
Old 11-21-2020, 12:20 PM   #2
norcalpb
norcalpb's Avatar
Here are a couple I like:
Old 11-21-2020, 12:32 PM   #3
snuff58
snuff58's Avatar
norcalpb
Thanks.
The first looks too narrow. What's the second one? I like the last two.
Old 11-21-2020, 01:27 PM   #4
norcalpb
norcalpb's Avatar
Originally Posted by snuff58 View Post
norcalpb
Thanks.
Second one is Perrin.
Verus was nice enough to do some virtual air flow testing on it:
https://www.verus-engineering.com/bl...ap-analysis-31
I’m iffy on it because it may produce a ton of drag at high speed, which our little engines don’t like. But real world application can always differ.
Old 11-21-2020, 01:49 PM   #5
snuff58
snuff58's Avatar
norcalpb
Not the Perrin unit, it mounts on the OE spoiler. I will remove my OE spoiler.
Old 11-21-2020, 01:54 PM   #6
snuff58
snuff58's Avatar
norcalpb
I can't find the second one (no name or logo) as Perrin. Would it mount directly on the back of the trunk lid?
Old 11-21-2020, 01:58 PM   #7
snuff58
snuff58's Avatar
The Perrin unit that mounts on the OE spoiler is listed as DISCONTINUED on 86speed website.
Old 11-21-2020, 06:06 PM   #8
norcalpb
norcalpb's Avatar
norcalpb
norcalpb
Well would you look at that, it is finally a discontinued product. And no I don't think it would fit without the stock spoiler like it is intended to be.
You can also try your hand in making your own, similar to this:
Old 11-21-2020, 07:20 PM   #9
snuff58
snuff58's Avatar
norcalpb
I think I'll look for a low profile unit to mount on the lid that will allow me to add a strip to it's back
Old 11-22-2020, 01:56 AM   #10
RayRay88
Drives: 2017 86 860 Special Edition
949 Racing project car:
RayRay88 is offline   Reply With Quote
Old 11-23-2020, 11:53 AM   #11
M0nk3y
Why are you so against adding a rear wing element?
Spoilers like the 949Racing car result in a high drag effect as a results of a massive wake zone immediately behind the element itself.
My Versus front splitter + UCW Rear Wing at 6* AOA resulted in 2 mph less VMax at Mid-Ohio (122 vs 120 mph) into China Beach and still was ~1.5 seconds faster on the same tire same conditions.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
strat61caster (11-23-2020)
Old 11-23-2020, 03:55 PM   #12
strat61caster
strat61caster's Avatar
You just made me realize that an adjustable rear wing could be moved to a lower drag config for the drive home because mpg because I'm driving this car Monday morning too...
ineedyourdiddly
Old 11-23-2020, 04:05 PM   #13
M0nk3y
Right, when I tow my car I throw my wing back to 0 AOA. I haven't really noticed any MPG hit on the towing aspect. DDing around back and forth to work (35 mph roads 10 miles total) I still get 28-29 MPG. Nothing abnormal.
Those type of spoilers do great at low speed (think all Street Prepared style classes). Anything above 60+ you're going to see a massive negative impact
Kyle H. - #89 STX
Old 11-23-2020, 04:59 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The drag from it is not bad. I have had one for years.
That is what I am planning to do with my GTC200. The drag from it is bad at minimum AOA. Going to build custom mounts with more adjustment.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
norcalpb (11-23-2020)
Will TRD style spoiler cover stock spoiler holes? jRuN Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2018 08:49 PM
Battle Aero Swan Neck Spoiler Paired W/ Rocket Bunny V2 Duck Bill Spoiler Preppy Cosmetic Modification (Interior/Exterior/Lighting) 30 02-10-2017 09:20 PM
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? FR-Sizzle Cosmetic Modification (Interior/Exterior/Lighting) 10 09-21-2015 02:29 PM
FS OEM BRZ Whiteout Spoiler or Trade for Rear Lip or Duckbill Spoiler Tripp1117 Exterior Parts (Aero, Lighting, Etc.) 1 07-11-2014 03:58 AM
Special: FRS/BRZ TRD & Stivo spoiler hybrid Spoiler design JonMotoring Groupbuys 22 06-23-2014 02:03 PM
