Old 09-19-2015, 04:16 PM   #1
FR-Sizzle
Drives: brz
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes?
I'm looking to get rid of the BRZ limited spoiler which just looks hideous. I want to get a duck spoiler instead and was wondering if any company makes use of the holes in the BRZ Limited spoiler on the trunk
FR-Sizzle is offline   Reply With Quote
Old 09-19-2015, 04:17 PM   #2
Porcupint
Drives: 13 GBS BRZ
None that use it that I know of. The Carsmo and TRD spoilers cover the holes though.
Porcupint is offline   Reply With Quote
Old 09-19-2015, 04:19 PM   #3
FR-Sizzle
Drives: brz
Having to cover up the holes for water n rain is what makes me not want to do it lt or have it swapped out with another wrb
Old 09-19-2015, 10:33 PM   #4
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
You can cover the holes with some waterproof taping before installing a new spoiler - problem solved. Otherwise, trunk swap is also a good idea.
Rookie84 is offline   Reply With Quote
Old 09-20-2015, 02:07 AM   #5
Irace86
Drives: BRZ + Ducati M796
Isnt there a VIN number on the trunk? Wouldnt a swap be bad for resale value?
Irace86 is offline   Reply With Quote
Old 09-20-2015, 12:47 PM   #6
bhmax
Drives: 13 BRZ, 17 Focus RS
I'm looking at TRD or replica for my Limited. Currently thinking about prepainted ones on eBay around $140. I actually had good luck with one from eBay on another car. Can't seem to find the actual TRD prepainted in Galaxy. Seems like the unpainted would be $500 after paint.
bhmax is offline   Reply With Quote
Old 09-20-2015, 01:34 PM   #7
Porcupint
Drives: 13 GBS BRZ
Ultramarine is the same color as GBS which helps a lot since GBS is no longer offered. OFT sells a TRD rep pre painted for $350.
http://www.openflashtablet.com/produ...ler/index.html
Old 09-20-2015, 01:51 PM   #8
Imrac
Drives: 13 SWP BRZ Prem
There is a sticker you can carefully swap :P, Just heat it up.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-20-2015, 02:09 PM   #9
adamg
Drives: brz
i started to make a list a while ago but the trd one is the most affordable. i got one of the preprainted ebay ones and the fitment and paint color was perfect
http://www.ft86club.com/forums/showthread.php?t=82478
adamg is offline   Reply With Quote
Old 09-20-2015, 02:52 PM   #10
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
if a rubber grommet can seal holes from rain (like the one that's already used by the factory to run wires to the trunk lid), then a dab of silicone can do the same. As long as the new spoiler covers the holes, you'll be fine.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-21-2015, 02:29 PM   #11
xxatsayxx
Drives: 2015 WRB BRZ
some vinyl should do the trick in covering the holes
xxatsayxx is offline   Reply With Quote
Spoilers that cover the BRZ Limited spoiler holes B-R-Z Cosmetic Modification (Interior/Exterior/Lighting) 19 10-25-2019 06:30 PM
3 pc trunk spoiler holes Raven240 Cosmetic Modification (Interior/Exterior/Lighting) 1 04-07-2015 03:31 PM
Will the BRZ/GT86/86 Factory Spoiler fit in the Factory FR-S Spoiler mounting holes? jbsali Cosmetic Modification (Interior/Exterior/Lighting) 1 02-13-2014 08:45 PM
BRZ lip spoiler to cover OEM holes J-W Cosmetic Modification (Interior/Exterior/Lighting) 3 12-05-2013 08:56 AM
Stock BRZ limited rear spoiler 86_Otaku Cosmetic Modification (Interior/Exterior/Lighting) 4 09-29-2013 06:55 PM
