Old 11-18-2020, 08:26 PM   #1
Purist
Purist's Avatar
Drives: Subaru BRZ
New BRZ No longer in 0-2000cc class!
In Australia many competitions use 2L as a class cutoff point. This puts the twins in a class with Lotus Elises, MR2s, MX5s and depending on the category, other NA hot hatches. The new 2.4 will see us potentially pitted against turbo 4s (FI multiplier is 1.7) and sixes.
Interested in the US take on this where the Auto X scene seems to feature a lot of twins.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 11-18-2020, 08:36 PM   #2
e1_griego
e1_griego's Avatar
Drives: Many
Cars here are classed on a car-by-car basis, at least for the SCCA.
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
Goingnowherefast (11-22-2020), strat61caster (11-18-2020)
Old 11-18-2020, 08:45 PM   #3
Purist
Purist's Avatar
Drives: Subaru BRZ
Do you mean tghat they ignore capacity to an extent and group by performace and weight etc.?
Less More
Old 11-18-2020, 09:00 PM   #4
e1_griego
e1_griego's Avatar
Drives: Many
Yeah, there are 6 'buckets' of classes for the SCCA -- Street, Street Touring, Street Prepared, Street Modified, Prepared, and Modified. And then within those 6 buckets have different strata in there (A, B, C, D, etc). Modifications to cars are specifically constrained within each bucket, and then cars are assigned to classes within the buckets.
Basically it's a big matrix.
The Following User Says Thank You to e1_griego For This Useful Post:
Old 11-18-2020, 09:12 PM   #5
strat61caster
strat61caster's Avatar
Vaguely yes. Right now the 86 gets classed with other light-ish RWD/FWD low horsepower coupes like the RX8 and Civic Si, sometimes the NC Miata, E36/E46 non-M BMW's, etc. It really depends on the organization, how they structure things, and what type of events they compete in.
Problem is that the new car is quick enough to obsolete the old car if they're classed together (most US orgs have set modification rules that apply to all chassis in the class, so if the old car is allowed an aftermarket tune, so is the new one, and on and on) but not probably not quite quick enough to challenge the next subset of popular grassroots cars. Best case scenario is it can hang with the Miata and get classed alongside the ND so most orgs can keep the old chassis alive, it's cheap and plentiful which builds good participation. Not sure if that'll shake out though.
ineedyourdiddly
Old 11-19-2020, 02:11 AM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
For big track racing theres always weight and restrictor plates to balance the performance of vehicles.
PRO86 | WTCC | STL
Old 11-19-2020, 02:39 AM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
So I've been in comps grouped by body shape against Exiges as well as MX5s, MR2s etc, and also in Production cars (any car with more than two seats)
I'm curious to know peoples thoughts on the ultimate fair grouping parameters to provide the best (fairest) competition. Shape? Seats? Weight? Power? Age? Capacity?
Since cars seem to always be compared to others in their price bracket, how about 'Price when new x capacity)
Anyone looking for a motorsport PhD topic??
Less More
Old 11-20-2020, 03:19 PM   #8
prandelia
Drives: 2015 FRS
Gimme that 184 lb-ft please!!!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 11-20-2020, 08:59 PM   #9
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
My local autocross group classes are based a points system where the primary points contributors are weight and power, with suspension, tires and other modifications contributing a certain number of points and you'd be dumped into classes based on points. I won series championship for my class despite only being like 1/3rd of the allowed points although full disclosure, it had less to do with being the fastest guy than it had to do with being the fastest guy who always showed up.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Purist (11-20-2020)
Old 11-20-2020, 09:08 PM   #10
Purist
Purist's Avatar
Drives: Subaru BRZ
Originally Posted by Lynxis View Post
... although full disclosure, it had less to do with being the fastest guy than it had to do with being the fastest guy who always showed up.
Don't sell yourself short. Thats part of racing. I've been in the same situation.
The points system sounds brilliant.
Less More
The Following User Says Thank You to Purist For This Useful Post:
Lynxis (11-20-2020)
Old 11-25-2020, 12:13 PM   #11
Icecreamtruk
Drives: Track preped NA FRS
Power to weight ratio with clearly defined aero rules (what is and isnt allowed) is what I think works best. Some chassis are better than others, there's no way around that. You could add restrictor or ballast to some chassis as well, but more often than not, fast drivers make cars look faster than they are.
Old 11-26-2020, 03:36 PM   #12
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I can't speak much for the autoX side of things, but in the time attack/time trials scene most sanctions in the US do not class cars based on engine size. The reason for this is simple, you can't compare two engines based on size only.
For instance,
F20C - 1,997 cc - Output: 234 HP/155 ft lbs
2.0 L SkyActiv-G - 1,998 cc - Output: 155 HP/148 ft lbs
One engine literally makes 79 more horsepower yet they are classed the same. I think really any sanction using displacement to class cars might want to get with the times haha.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-26-2020, 05:27 PM   #13
86TOYO2k17
Drives: 2017 toyota 86
For instance,
They should, but not by simply looking at only peak numbers.
Old 11-26-2020, 06:32 PM   #14
Goingnowherefast
AKA what NASA does. They look at average HP. SCCA does a good job (IMHO) in TT without that by predicting how fast car X will be, but obviously it takes a year to really know.
NO LONGER NEED DarkPira7e Want-To-Buy Requests 0 12-05-2017 12:16 AM
What class would I be? zerobrz Tracking / Autocross / HPDE / Drifting 3 10-29-2017 08:44 AM
no longer available AllOutApex Australia Classifieds 0 01-20-2016 08:08 PM
No longer available funx Canada Classifieds 3 10-29-2013 09:10 AM
Anyone for a class? Fuzzysmith Northwest 21 08-13-2012 12:02 PM
