Drives: Subaru BRZ
New BRZ No longer in 0-2000cc class!
In Australia many competitions use 2L as a class cutoff point. This puts the twins in a class with Lotus Elises, MR2s, MX5s and depending on the category, other NA hot hatches. The new 2.4 will see us potentially pitted against turbo 4s (FI multiplier is 1.7) and sixes.
Interested in the US take on this where the Auto X scene seems to feature a lot of twins. Sent from my SM-G973F using Tapatalk |
#2 |
Drives: Many
Cars here are classed on a car-by-car basis, at least for the SCCA.
| The Following 2 Users Say Thank You to e1_griego For This Useful Post: | Goingnowherefast (11-22-2020), strat61caster (11-18-2020) |
#3 | |
Drives: Subaru BRZ
#4 |
Drives: Many
Yeah, there are 6 'buckets' of classes for the SCCA -- Street, Street Touring, Street Prepared, Street Modified, Prepared, and Modified. And then within those 6 buckets have different strata in there (A, B, C, D, etc). Modifications to cars are specifically constrained within each bucket, and then cars are assigned to classes within the buckets.
Basically it's a big matrix. |
| The Following User Says Thank You to e1_griego For This Useful Post: | strat61caster (11-18-2020) |
#5 | |
Drives: '13 FRS - STX
Problem is that the new car is quick enough to obsolete the old car if they're classed together (most US orgs have set modification rules that apply to all chassis in the class, so if the old car is allowed an aftermarket tune, so is the new one, and on and on) but not probably not quite quick enough to challenge the next subset of popular grassroots cars. Best case scenario is it can hang with the Miata and get classed alongside the ND so most orgs can keep the old chassis alive, it's cheap and plentiful which builds good participation. Not sure if that'll shake out though. |
#6 |
Drives: Nevermorange FRS
For big track racing theres always weight and restrictor plates to balance the performance of vehicles.
PRO86 | WTCC | STL
#7 |
Drives: Subaru BRZ
So I've been in comps grouped by body shape against Exiges as well as MX5s, MR2s etc, and also in Production cars (any car with more than two seats)
I'm curious to know peoples thoughts on the ultimate fair grouping parameters to provide the best (fairest) competition. Shape? Seats? Weight? Power? Age? Capacity? Since cars seem to always be compared to others in their price bracket, how about 'Price when new x capacity) Anyone looking for a motorsport PhD topic?? Sent from my SM-G973F using Tapatalk |
#8 |
Drives: 2015 FRS
Gimme that 184 lb-ft please!!!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
#9 |
Drives: 2013 WRB BRZ 6MT
My local autocross group classes are based a points system where the primary points contributors are weight and power, with suspension, tires and other modifications contributing a certain number of points and you'd be dumped into classes based on points. I won series championship for my class despite only being like 1/3rd of the allowed points although full disclosure, it had less to do with being the fastest guy than it had to do with being the fastest guy who always showed up.
| The Following User Says Thank You to Lynxis For This Useful Post: | Purist (11-20-2020) |
#10 | |
Drives: Subaru BRZ
The points system sounds brilliant. Sent from my SM-G973F using Tapatalk |
| The Following User Says Thank You to Purist For This Useful Post: | Lynxis (11-20-2020) |
#11 |
Drives: Track preped NA FRS
Power to weight ratio with clearly defined aero rules (what is and isnt allowed) is what I think works best. Some chassis are better than others, there's no way around that. You could add restrictor or ballast to some chassis as well, but more often than not, fast drivers make cars look faster than they are.
#12 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I can't speak much for the autoX side of things, but in the time attack/time trials scene most sanctions in the US do not class cars based on engine size. The reason for this is simple, you can't compare two engines based on size only.
For instance, F20C - 1,997 cc - Output: 234 HP/155 ft lbs 2.0 L SkyActiv-G - 1,998 cc - Output: 155 HP/148 ft lbs One engine literally makes 79 more horsepower yet they are classed the same. I think really any sanction using displacement to class cars might want to get with the times haha.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#13 | |
Drives: 2017 toyota 86
#14 |
AKA what NASA does. They look at average HP. SCCA does a good job (IMHO) in TT without that by predicting how fast car X will be, but obviously it takes a year to really know.
| NO LONGER NEED | DarkPira7e | Want-To-Buy Requests | 0 | 12-05-2017 12:16 AM |
| What class would I be? | zerobrz | Tracking / Autocross / HPDE / Drifting | 3 | 10-29-2017 08:44 AM |
| no longer available | AllOutApex | Australia Classifieds | 0 | 01-20-2016 08:08 PM |
| No longer available | funx | Canada Classifieds | 3 | 10-29-2013 09:10 AM |
| Anyone for a class? | Fuzzysmith | Northwest | 21 | 08-13-2012 12:02 PM |
