Old 11-18-2020, 07:01 PM   #1
Simok
Drives: 2013 FRS
Soft clutch?
So I recently took my car to the dealer to have the tob replaced. I had them install the new part# tob, oem clutch, resurfaced flywheel, versus engineering clutch fork, pivot, and bell housing cover.
The first time I went to pick it up it wouldnt go into first or second gear. I left it and they corrected that issue. I picked it up again today and the clutch feela very soft/easy to push. My previous clutch was by no means hard to push, but there was definitely much more resistance. I would think it should be the oppostie. Havent driven it too much yet, but it appears to be going into gear just fine.
Is this normal for a new clutch to be softer? Or is it something to worry about? Or do I just need to get used to it?
Simok is offline   Reply With Quote
Old 11-18-2020, 07:05 PM   #2
Clark20
Clark20's Avatar
Drives: 2019 BRZ PP
Almost same exact thing happened to me when I went and got my TOB replaced. The pedal was super light after they changed it. It ended up going to back to normal soon after though.
Sent from my SM-N960U using Tapatalk
Clark20 is offline   Reply With Quote
Old 11-18-2020, 08:17 PM   #3
humfrz
An easy to push clutch should be a good thing.
I suggest you just enjoy it -
Old 11-18-2020, 10:00 PM   #4
dholloway543
Software Hobbiest
Drives: 2015 FRS
I experienced the same thing after the versus clutch fork install. I think it just needs adjustment to the petal as the fork might not be the same exact shape as stock
dholloway543 is offline   Reply With Quote
Old 11-18-2020, 11:45 PM   #5
Decep
Drives: 2013 FR-S Series 10
Probably how it was designed to feel tbh. You're just not used to it.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 11-18-2020, 11:54 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Maybe it's working properly now.
Old 11-20-2020, 08:15 AM   #7
Grady
Grady's Avatar
Break in the clutch then do some hard launches. If clutch holds you are good.
Clutch feels soft? Easier? NJNCFRS Engine, Exhaust, Transmission 8 03-02-2018 10:54 PM
WRB clearcoat / paint soft?? cookiesowns BRZ First-Gen (2012+) — General Topics 7 09-10-2014 12:01 AM
I want a soft ride PeterB Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 12-31-2012 11:49 PM
Soft Clutch fix Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2012 05:03 PM
