Old 11-16-2020, 12:00 AM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
transmission rattle
The noise is a harsh what sounds like the gears meshing metal on metal sound. Mostly heard holding speed at 3000rpm or on engine breaking decel.
I read a couple places and it seems it might be the nature of unsprung clutches because the engine pulses are put more direct into the trans and also the fact that I have a lightweight flywheel which is less momentum for each pulse.
I'm pretty sure the noise was there before I swapped my exedy stg2 clutch for the os giken counter space garage version clutch kit but I feel the rattle has gotten worse since the installation.
Does anyone else experience this? I'm just trying to find out if it's normal or if I need to take my trans for repair?
https://photos.app.goo.gl/52vc3mTXHc23w1ob7
dholloway543 is offline   Reply With Quote
Old 11-16-2020, 07:48 AM   #2
Ashikabi
Ashikabi's Avatar
Don't bother repairing it. Those transmissions are dirt cheap. Just put a used one on it you need to.
Transmission rattle in Neutral msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-27-2022 01:38 PM
Transmission rattle msaikhan Issues | Warranty | Recalls / TSB 8 08-23-2019 05:58 PM
transmission scratch/rattle when cold lp87 Engine, Exhaust, Transmission 2 01-16-2015 10:34 AM
any one has Transmission Rattle like me ? ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 36 07-29-2013 11:41 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
