Old 06-15-2019, 02:32 PM   #1
msaikhan
Drives: frs
Transmission rattle
2013 frs manual 125k
There is a rattle coming from tranny and goes away when clutch is pressed. Replaced the clutch with exedy few months ago. Throw out and pilot bearing shouldve been replaced. Done by dealer.
It's not a whine, its rattling like a loose bolt inside the bell housing. What bearing do u think is going bad.
msaikhan is offline   Reply With Quote
Old 06-15-2019, 02:49 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
None. It's normal. Rattle started when thick factory trans fluid was replaced with something that doesn't hide the noise as well.
Google "neutral rollover." As long as it's quiet when under torque, and shifts properly, motor on happily.
Old 06-15-2019, 05:27 PM   #3
msaikhan
Drives: frs
Hmm really...
But the rattle been getting more frequent. It used to come and go. But today it's been doing it pretty consistent.
I've been using motul for almost a year. And the rattle only started couple months ago.
Old 06-15-2019, 05:48 PM   #4
Ultramaroon
not playing cards
Oh, I'll change my opinion in a heartbeat. I'm on my second transmission. It's a long story but I know exactly what I did to my first. Other experienced ears couldn't hear it but I know I found the limit. I took it out of service to keep it from wearing out of whack before getting around to replacing the input shaft bearing. Besides, I want to build a track-only trans. I digress.
If you gently lean on each of the syncros just for a moment with the clutch disengaged, engine idling, does the sound change dramatically?
Also, I've heard of TOB retaining pins falling out.
I'll listen for it with my headphones if you post a recording.
Old 06-16-2019, 07:53 AM   #5
Grady
Grady's Avatar
Have you tried turning the A/C off to see if it goes away? Mine started when I put a lightweight flywheel on. Supposedly this is normal harmonic vibration noise. Probably not good for the transmission long term but nothing you can do about it but go back to stock.
Old 06-16-2019, 10:17 AM   #6
msaikhan
Drives: frs
I have stock flywheel. I haven't tried turning off ac. but it rattles without it being on and it's been getting more frequent which worries me.
Old 06-16-2019, 01:40 PM   #7
KingJon1991
Drives: scion frs 2015
it the clutch fork i have the same problem a/c or off
KingJon1991 is offline   Reply With Quote
Old 06-18-2019, 02:08 PM   #8
Tonypepatone
Drives: 2013 ScionFRS
Did you replace the flywheel or at least get it resurfaced?
Sent from my SM-G950U using Tapatalk
Tonypepatone is offline   Reply With Quote
Old 08-23-2019, 05:58 PM   #9
supahotfya_86
Drives: Firestorm FR-S
my transmission is sounding the same, i drop it last night TOB and everything looks normal. input shaft does have some play to it. i'm thinking a need a new trans cause it is hard to even put into gear at a stand stiff with the clutch fully pressed.
supahotfya_86 is offline   Reply With Quote
Transmission rattle in Neutral msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-27-2022 01:38 PM
transmission scratch/rattle when cold lp87 Engine, Exhaust, Transmission 2 01-16-2015 10:34 AM
any one has Transmission Rattle like me ? ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 36 07-29-2013 11:41 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
