Old 11-10-2020, 01:36 PM   #1
Jonatanv98
Drives: 2017 BRZ
Clutch pedal making weird noises
So recently my clutch pedal on my ‘17 BRZ has been making creaking sounds which I think might just be need of lube. But today it started making like a tapping sound or a knocking sound every-time I fully pressed on it especially if I did it hard, I’m not sure if it’s normal and I never payed attention to it before but yeah. I have a video of it just not sure how to post or link it here in the forum.
Jonatanv98 is offline   Reply With Quote
Old 11-10-2020, 09:16 PM   #2
humfrz
Welcome to the forum, there, Jonatanv98 -
The sound may be coming from a dry clutch fork. If so, this technique may shut it up:
Quick & dirty: from @Ultramaroon
1. Detach the slave cylinder. Leave the hydraulics alone.
2. Remove the dust boot from the fork.
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger.
5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own.
6. Put a dab of grease in the top pivot where the slave pin goes.
7. Reassemble.
clutch
More strange noises pedal area. Butterballz Issues | Warranty | Recalls / TSB 15 09-16-2019 05:42 PM
Clutch Pedal Making [Rubber] Noise DaBoBo21 Issues | Warranty | Recalls / TSB 15 01-23-2018 08:56 AM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 06:04 PM
Weird noises mamamiaellis Issues | Warranty | Recalls / TSB 4 05-30-2014 04:17 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
