Old 05-27-2014, 12:50 PM   #1
mamamiaellis
Drives: brz
Weird noises
First post here guys!
Sorry if it's a noob question and if it's in the wrong section.!!!
I've had my brz for almost 5 months.
About 3500 miles
I have a perrin catback and an air filter installed
Lately from 2.5k-3k rpm I hear a sort of hissing noise
And I can feel it on the throttle (maybe because my ears confuse my sense of touch) is this normal?
Also in any gear when I apply more than 80% throttle, I have this high frequency pinging noise from the engine. It was not like this the first day I took it home.
Anyone know the issue?
Thanks for reading!
mamamiaellis is offline   Reply With Quote
Old 05-29-2014, 01:18 AM   #2
humfrz
About 3500 miles
Thanks for reading!
Welcome to the forum, @mamamiaellis ...
Are you using top tier, high octane gas .. ??
If you plug up the sound tube, do you still hear those sounds .. ??
Is your car's air filter box closed up tight .. ??
humfrz
Old 05-29-2014, 11:46 AM   #3
Mr 286
Mr 286's Avatar
Drives: 2014 Camry SE V6 | 1991 MR2 Turbo
See my response on this thread about the hissing:
http://www.ft86club.com/forums/showthread.php?t=66854
My hissing turned out to be a pilot bearing. The pinging might even be related. You have very low miles to be having a similar issue to what I experienced though. I mean, it could occur at any mileage, but just seems less likely.
Mr 286 is offline   Reply With Quote
Old 05-30-2014, 04:05 PM   #4
mamamiaellis
Drives: brz
I run 91 chevron normally. Never anything lower.
My air box should be tight (I could always double check :P)
And I never tried deleting the sound tube.
As for the pilot bearing. I somewhat skimmed your post. It's in he clutch?
I went to subaru earlier this week. They said everything checked out normal.
And as for the high pitch ping, it's the fuel pump compensating the WOT.
I hope it doesn't get worse and start rattling like you mentioned.
Thanks for your inputs dudes.
Old 05-30-2014, 04:17 PM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Yaks make some weird noises.
Anybody else have noises after lowering? Tiremonkey0824 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-08-2014 08:11 PM
Pebbles and road debris noises FatFree Scion FR-S / Toyota 86 GT86 General Forum 25 12-18-2013 10:10 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 12:26 AM
