Old 11-07-2020, 12:45 AM   #1
Camnaka123
Drives: 2014 scion frs
Unhappy engine won't crank after replacing battery
several days ago I replaces my battery after having slow starts which led to not starting at all, after jumping the car to go get a new battery I installed the battery and everything started just fine, no lights or anything. I let the car sit for 2 days and took it for a drive today, while driving I realized that both my ABS and traction control lights were on but they would turn off if I came to a stop then back on again once I started driving. i got back parked and turned off the car then I checked the battery to see if it was loose in any way but it was tight I then tried to start the car and it wouldn't even crank, after it not cranking I started pulling fuses to see if it was a blown abs fuse or starter fuse and after replaces several fuses that weren't blown but looked worn the car still has yet to even crank over. I have a feeling it is something that happened when I replaced the battery because before the car was perfect like I said it didn't have any kind of warning lights for anything before
Camnaka123 is offline   Reply With Quote
Old 11-07-2020, 01:13 AM   #2
Decep
Drives: 2013 FR-S Series 10
maybe it's a bad battery.. not the first time it's happened
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 11-07-2020, 06:15 AM   #3
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
voltage is?
thomasmryan is offline   Reply With Quote
Old 11-07-2020, 08:57 AM   #4
What the other guys said ^
I have had bad brand new batteries before. It happens. Start there and if it is good take the cables back off and clean them. If it still doesn't start then things are getting weird!
Old 11-07-2020, 09:06 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
also inspect the fuse on the battery terminal
Old 11-07-2020, 01:57 PM   #6
Camnaka123
I just got the battery check and it is fully charged, I didn’t mention the previous owner put a subwoofer in the back but I ended up disconnecting and taking out idk if that would have anything to do with it
Old 11-07-2020, 02:58 PM   #7
humfrz
And the fuse on the battery terminal?
Old 11-07-2020, 06:57 PM   #8
Have you done any other work on the just before the issue started?
Old 11-08-2020, 02:11 PM   #9
Camnaka123
No none, just the new battery. I think it’s very strange that my car was completely fine before I replaced the battery then after replacing it all of these issues started helping
Old 11-08-2020, 02:14 PM   #10
Camnaka123
It looks to be fine, is there a possibility that a blown terminal battery fuse could stop the engine from cranking?
Old 11-08-2020, 04:31 PM   #11
soundman98
soundman98's Avatar
Yes. Use an ohm meter to check it
battery replacement, crank, engine issue, won't start
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
replacing the crank pulley on automatic mrg666 Engine, Exhaust, Transmission 35 08-14-2018 06:20 AM
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 10:46 AM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 05:44 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
