Old 07-26-2017, 09:02 PM   #1
cnxmist
Drives: 2013 Subaru Brz Limited Automatic
Crank No start (Not battery issue) NEED HELP
HELP!!! my car (2013 Subaru BRZ Limited Auto) was running the other day, and suddenly stall out on me on the freeway, now it crank over but doesn't start, the only code that was stored prior to the incident is P0031 and P0560. Any info lead to fixing would be appreciated
- replaced the O2 Sensor
- Check Battery and replaced
Car was running on Fwy then lost power = stall out didnt start after that
cnxmist is offline   Reply With Quote
Old 07-26-2017, 09:38 PM   #2
Fully stock?
Engine mods?
Old 07-26-2017, 11:49 PM   #3
cnxmist
Hi Tcoat, Yes Engine is fully stock no mod
Just check the Alternator still good and charging battery 11.6v
Battery measure at 12.6v
Compression on all Cylinder is within spec at 135 PSI
Check all the relay and Fuses non blown or damage
Old 07-27-2017, 12:34 AM   #4
cnxmist
Some picture of the spark plug, look very odd with some flake. Going to replace them but does anyone know what wrong with it, doesn't look like loctite to me
[IMG]<iframe width="480" height="360" src="http://s1255.photobucket.com/user/cnxmist/embed/slideshow/spark%20plug"></iframe>[/IMG]
Old 07-27-2017, 12:46 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Plugs are perfect. Just clean them before reinserting. Just combustion byproducts baked into the threads.
Without doing any tests, I'll guess alternator. Your voltages are low.
https://demos.starbase7.net/t3Portal...00T8P0ZQX.html
Old 07-27-2017, 03:43 AM   #6
cnxmist
I will replace the alternator tomorrow and get back to you, what else can I check?
Old 07-27-2017, 05:26 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Do yourself a favor- you do not know how to diagnose. You are throwing parts blindly at the problem hoping to fix the issue you don't know. TAKE IT TO A SHOP and have them diagnose. You have no clue whether the alternator is any good because you can't even get the engine going. You blindly changed out an O2 sensor (did you even replace it with the right one?) and for some reason you are looking at plugs. Batt voltage is good but what's the CCA? Who cares anyway, that won't cause a car to stall.
YOU are going to run out of money before you run out of parts and you've already wasted a bunch of money anyway. Pay a pro to find the issue. Then you can change out the parts once you know what parts to change out.
You haven't even checked fuel pressure SMDH
Old 07-27-2017, 01:27 PM   #8
Ultramaroon
not playing cards
I recommend against blind replacement as well. That was just a suggestion for a place to consider. Sorry about not being more clear.
Nothing wrong with pulling the alternator and having it tested. Most auto parts places can throw it onto a machine and check it.
Old 07-27-2017, 02:46 PM   #9
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Is timing chain still intact ? Does it sound like it normally does when cranking or faster and easier ?
22R
22R is offline   Reply With Quote
Old 07-27-2017, 02:48 PM   #10
humfrz
It would appear that your alternator may be bad.
The voltage at the battery with the engine running should be around 13.5 volts.
http://www.aa1car.com/library/battery_runs_down.htm
humfrz
Old 07-27-2017, 03:09 PM   #11
humfrz
Car won't start.
Old 07-27-2017, 03:20 PM   #12
P0560 - System Voltage Malfunction
Repair Importance Level: 3/3
Repair Difficulty Level: 3/3
Forum Code
Possible causes
  • Low battery charge
  • Battery defective
  • Loose or missing alternator drive belt
  • Faulty alternator
  • Open or short system voltage circuit
Yes^
22R
Really? Jump to the timing chain? There would be 100 codes if that was the case.
Again with people going to worst case and skipping every other possible solution. Sorry to be abrupt but this is a pet peeve of mine. Maybe once other more basic things have been checked it would get to that but random, out of the blue, guesses send people into panic mode and wastes time in wild goose chases.
Old 07-27-2017, 03:25 PM   #13
cnxmist
@guybo yes it true that I don't know what I'm doing, that the whole reason why I requested assistance for other board members to point me in the right direction, and wanted to know the cause, I do know that I order a car to start its need compression spark fuel and timing.
Also by no mean I change out parts blindly, when a member pointed out that the alternator might be bad I will look into the parts and test prior to replace.
I already eliminated fuel as the pump still function, there fuel pressure and the fuse is not blown.
I'm here requesting for assistance to fix the issue at hand any opinion that point me to fixing the issue with be appreciated, but if the comment that just " bring it to a shop" or "you don't know what your doing" is not helpful
Old 07-27-2017, 03:35 PM   #14
As odd as this sounds you should hope it is indeed the alternator that is the issue. As the code info I posted above says the other possible source is an "open or short system voltage circuit" and that could be a real bitch to chase down.
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
Car won't start, won't crank, no ecu communication redlined600 Issues | Warranty | Recalls / TSB 10 07-09-2016 12:55 PM
Car Won't Start.. No Lights.. Not a battery or fuse issue.. pleong Scion FR-S / Toyota 86 GT86 General Forum 11 09-23-2015 04:45 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 06:22 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
