Old 11-02-2020, 07:15 PM   #1
fdf
Drives: 2013 Subaru BRZ
Thoughts on ACT HD Clutch
Hello everybody,
So I've hit that inevitable point when my throwout bearing is starting to go bad and I figure I might as well replace my clutch while I'm getting the TOB replaced. I've had experience with the Exedy Stage 2 Clutch and that thing chattered like crazy so I don't want to go that route again. This time around I'm leaning towards the ACT HD/Perf Street Sprung Clutch Kit with the Streetlite Flywheel (SB7-HDSS). I was wondering if any club members who have had this clutch kit could tell me about the amount of chatter this kit causes.
fdf is offline   Reply With Quote
Old 11-02-2020, 07:44 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Who wants to go first.......
Old 11-02-2020, 08:00 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
But What might want to go second...
Old 11-02-2020, 08:02 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I don't know third?
Old 11-02-2020, 08:14 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (11-02-2020), HKz (11-20-2020)
Old 11-02-2020, 08:58 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Exemplary example of a great first post! Welcome to AskJeeves 2.0
The Following User Says Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (11-03-2020)
Old 11-02-2020, 10:21 PM   #7
fdf
Most of the forum posts discussing that specific ACT clutch are people that either run the Prolite flywheel or are still in the process of breaking it in.
Old 11-03-2020, 01:37 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I'm feeling nice.
To OP.
Get something else.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
churchx (11-03-2020), dhuang (11-03-2020), NoHaveMSG (11-03-2020)
Old 11-03-2020, 10:41 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by x808drifter View Post
I'm feeling nice.
To OP.
Get something else.
yup. literally every thread about a clutch not disengaging 500 miles after newly installed seems to be an ACT model.
sroby (11-30-2020)
Old 11-08-2020, 01:26 PM   #10
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I have the ACT SB7-XTSS, no issues. I did get the velox shift fork and ball installed when I swapped it out. Make sure you use a new TOB, not what comes in the box. The plastic clutch alignment tool in the kit is garbage, if you use that I wouldn't be surprised people had issues after 500 miles. I am going on several thousand miles without issue. If I drive for 60+ miles it will start to chatter at idle, not a big deal, get your tuner to up your RPMs at idle. Don't go with the prolite, get the *normal* FW, it's still half the weight of your stock flyhweel.
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
CSG Mike (11-16-2020), smg1138 (01-24-2021)
Old 11-08-2020, 02:24 PM   #11
jflogerzi
jflogerzi's Avatar
Look at Southbend + OEM Fly Wheel
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
DarkPira7e (11-08-2020), sroby (11-30-2020)
Old 11-09-2020, 01:02 AM   #12
Smaay
Drives: 2013 FRS
Southbend.
Smaay is offline   Reply With Quote
Old 11-16-2020, 02:59 PM   #13
Any competent mechanic should have a metal alignment tool for the clutch. The plastic one provided is garbage. They'd be better off just not providing one at all.
Virtually every issue I've seen with the ACT clutches are installation related.
IMO, the ACT is the best bang for the buck clutch.
If you want to do a fork upgrade, and TOB upgrade (!!!!), OS Giken is the way to go.
smg1138 (01-24-2021), Trueweltall (11-18-2020)
Old 11-20-2020, 04:06 PM   #14
prandelia
Drives: 2015 FRS
Yeah, can't go wrong with the ACT HD. Had it in my car before I switched to a lighter flywheel. Now running the Sachs Performance setup, with Exedy LWFW.
Although both have similar clamping force, the HD is prob better if you DD the car, as the pedal effort is considerably lighter due to the design. Plus, a great price!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Thoughts and Prayer <> Aamco is doing my new clutch gravitylover BRZ First-Gen (2012+) — General Topics 28 10-10-2018 11:11 AM
New OEM clutch! Thoughts. radroach Engine, Exhaust, Transmission 5 10-14-2015 06:07 PM
Thoughts about rebuilding stock clutch. (or, conversation about friction materials) qtwre Engine, Exhaust, Transmission 0 07-09-2014 01:56 PM
Clutch Master's FX300 Thoughts Opinions evilconcarne999 Engine, Exhaust, Transmission 16 07-03-2013 02:21 PM
