Drives: 2013 FRS GTX3076R
Copy and pasting AVCS tables help.
Hello, wondering if anyone can provide insight to the following issue im having. I am trying to use ECUTEK to flash an OFT Stage 2+ working on my car which has the cal id ZA1JA00C. Obviously I can't just flash the OFT map directly. So I was using a stock ZA1JB01C ROM and copying the tables from the OFT STG2+ map which has the cal id ZA1JA01G cal id to the B01C ROM.
Everything was going fine until I get to the 'Exhaust cam retard angle base AVCS' and 'Intake Cam Advance Angle AVCS' tables for some reason when I copy tables for the exhaust AVCS it completely messes up the values for the intake AVCS and vice versa. I am using ECUFLASH to do this. Thanks in advance. Sent from my SM-G950W using Tapatalk |
#2 | |
Its likely there is a slight mismatch between the A01G defs and the B01C defs you could try using romraider but the A01G rom is compatable with B01C so might be easier jist to ise A01G |
Drives: World Rally Blue Subaru BRZ
Hey did you ever get this working? if so could you PM me?
Drives: Subaru BRZ 2016
Sometimes copying the tables to Excel first, then copying them back into the rom editor works. I don't know why, but it has worked for me.
| Tuning AVCS without a dyno (AVCS for Gruppe-S header post 12 and 24) | Tor | Software Tuning | 90 | 08-30-2026 03:41 AM |
| Help Understand OTS4.0 vs OTS vs Wayno 2.0 UEL VVT AVCS Tables | neilvosko | Software Tuning | 18 | 06-08-2020 05:21 PM |
| New copy key | phongtphan21 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 05-22-2016 03:04 AM |
| Five axis copy | Hawk77FT | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-12-2014 08:46 AM |
| Help Copying & Pasting PDF Characters | Captain Snooze | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-09-2014 09:22 AM |
