Old 10-16-2020, 01:48 PM   #1
yzf219
Drives: 2013 FRS GTX3076R
Using Ecutek to flash OFT maps
Hi everyone, I have an Ecutek and wish to use the Ecutek to flash OFT maps. My car currently has an Ecutek tune. Based on my searches on this forum I still have several questions.
Is this even possible? I've heard conflicting answers ranging from no you can't, to yes but the oft maps differ or are missing some data.
If I am able to flash OFT maps using Ecutek will my Ecutek licence still remain intact once I flash the OFT maps?
Thanks in advance any help is appreciated.
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 10-16-2020, 03:46 PM   #2
degozaru
Drives: 2016 oceanic frs
no
degozaru is offline   Reply With Quote
Old 10-17-2020, 07:46 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, you can so long as it doesn't have the OFT Launch control patch and isn't Cal ID "hacked" to work on OFT.
EcuTek license will stay on the ECU if you do this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-17-2020, 11:19 AM   #4
yzf219
Thank you! Good explanation, answered all my questions.
Old 10-18-2020, 05:35 AM   #5
steve99
As Kodename47 said the lc/ffs patch stops you being avle to add racerom patch which you need to flash a non stock tune so if your manual your out of luck.
Then if your auto unless your car is A01I or K01I you going to run into problems with calid hacks in oft roms and ecutek not wantong to let you flash what is considers non compliant roms.
Now you can get arround those issues by several means but unless you have ecutek tuner version you need to manually copy and paste all the changed tables into into a non lc\ffs patched or non calid hacked rom which will take a considerable period of time.
Short answer is yes but for most people its not worth the trouble.
Using Ecutek to flash OFT maps yzf219 Scion FR-S / Toyota 86 GT86 General Forum 3 10-27-2020 09:41 PM
Port OFT maps to Ecutek gpvecchi Software Tuning 3 05-14-2020 01:14 AM
EcuTek Base maps? Rederick Software Tuning 4 01-11-2018 06:24 AM
Open Flash & Vortech WHERE ARE THE MAPS? ScionFR-S Software Tuning 2 07-12-2015 05:53 PM
Can't seem to swap maps Ecutek Vex Software Tuning 3 07-02-2014 05:57 PM
