Old 05-12-2020, 05:06 PM   #1
gpvecchi
gpvecchi's Avatar
Port OFT maps to Ecutek
I got annoyed during lockdown, so I would like to play a little with Ecutek.
Is it possible to port the OFT (like stage 1, 2 etc.) maps to Ecutek? I presume you have to manually copy the tables...
gpvecchi is offline   Reply With Quote
Old 05-13-2020, 06:36 AM   #2
steve99
If it Auto you can jist pull it into ecutek, if its manual you will need to manually transfer tavles due lc\ffs patch
you can only use non calid altered roms or ecutek will be confused
Old 05-14-2020, 01:05 AM   #3
gpvecchi
gpvecchi's Avatar
Thanks, manual. So I'll just manually copy tables, can you point me which ones? All the cam timings and which ones?
Old 05-14-2020, 01:14 AM   #4
tomm.brz
Drives: brz 2017 hksv2
Since we are lacking compare function in our ProEcu suites, it s easy to mess with ecutek if you dont know where to go
If you want to know what s changed from oem tune in ots maps, open them in romraider together with the equivalent oem tune and use the Compare and it shows you all the modified tables
then you can manually copypaste them into ecutek if you want, if you use A01G or K00G, they aren't calid hacked and they ll open in ProEcu to read from them
EcuTek Base maps? Rederick Software Tuning 4 01-11-2018 06:24 AM
EcuTek maps separate learning or not? PR138 Software Tuning 2 08-18-2017 04:36 PM
Ecutek Help, Can't seem to choose maps Allan13 Software Tuning 5 12-31-2014 12:55 PM
Can't seem to swap maps Ecutek Vex Software Tuning 3 07-02-2014 05:57 PM
EcuTek ProECU PI/DI Maps Added EcuTek Software Tuning 1 12-22-2013 10:23 AM
