Old 10-10-2020, 11:07 PM   #1
xZAMx
Drives: '13 FR-S - Hot Lava
Stock speakers have better bass than aftermarket - help!
I replaced my door speakers with pioneer ts-m650pro door speakers and I have a scion pioneer head unit. The new speakers' bass is a lot worse than the stock ones. I assume it has to do something with the stock amp? Not sure what my options here are.
Thanks!
xZAMx is offline   Reply With Quote
Old 10-10-2020, 11:27 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
The stock speakers are 2 ohm. Installing 4 ohm drivers will lower output. The speakers you bought are also crap for bass extension as they specifically say they are midbass drivers. The door speakers on this car are subwoofers.
Your options are:
Gut the stock system and install a subwoofer like pioneer intends for use with those drivers
Replace the drivers with the stock speakers
Have some custom built 2 ohm 6" subwoofer drivers that are less 3" deep installed
Old 10-10-2020, 11:36 PM   #3
xZAMx
Thanks for the he explanation. No wonder why the seller threw them in for free with the knee pads =]
Old 10-12-2020, 01:42 AM   #4
Griever423
Drives: 2020 BRZ PP
The stock door speakers actually aren't bad. They do distort some at higher volumes but if you're running the factory head unit then you're not going to see a TON of difference with aftermarket speakers unless yours are blown.
Griever423 is offline   Reply With Quote
Old 10-12-2020, 08:19 PM   #5
bfrank1972
Drives: 2013 FR-S Argento
I second that - I have the oem audio + setup which uses an aftermarket amp, dependable, tweeters and subwoofer. It tunes for the stock woofers and raises crossover to reduce distortion and it sounds pretty darned good.
Sent from my SM-G965U using Tapatalk
bfrank1972 is offline   Reply With Quote
Aftermarket Pioneer Radio & Polk Component Speakers Install Help! SkyeHack Electronics | Audio | NAV | Infotainment 3 05-04-2020 11:05 PM
Adding Bass to stock system? Roneezy Electronics | Audio | NAV | Infotainment 74 05-19-2016 11:31 AM
Aftermarket amp + speakers, sounds not as great AL008 Electronics | Audio | NAV | Infotainment 24 06-23-2013 12:32 AM
Aftermarket speakers/amp w/bespoke. Hands free calling. Ruckus Electronics | Audio | NAV | Infotainment 2 04-14-2013 09:47 PM
Help:new aftermarket radio and question regarding speakers FR-Shadow Electronics | Audio | NAV | Infotainment 2 11-04-2012 07:58 PM
