Old 10-05-2020, 11:47 AM   #1
yzf219
Drives: 2013 FRS GTX3076R
Cheaper upgraded motor mount options??
Hi just wondering if there are any cheaper upgraded motor mount options? I don't wish to pay $300-400cad for mounts. Are there any OEM upgrade options like out of a 2015+ WRX or STI? Can the factory mounts be filled with window weld?
I was looking and it seems like 2015 WRX engine mounts are a fit, but the part number on Rockauto is the same as an FRS so it doesn't look like it'll be much of an upgrade.
Thanks.
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 10-05-2020, 11:56 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
https://sidewaysfab.com/collections/...-brz-toyota-86
Solid mounts, $100 bucks! Mounts are a do it once, do it right kind of upgrade. Why do you want to upgrade the motor mounts of all things?
I'd highly recommend spending the money to get good mounts- the NVH people talk about isn't just some thing that's really easy to live with, it can be bad enough to make your hands go numb from holding the steering wheel.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
humfrz (10-05-2020), Joveen (10-11-2020), yzf219 (10-05-2020)
Old 10-05-2020, 12:07 PM   #3
humfrz
Same question??
yzf219 (10-05-2020)
Old 10-05-2020, 12:29 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hockey Puck?
The Following User Says Thank You to x808drifter For This Useful Post:
yzf219 (10-05-2020)
Old 10-05-2020, 05:01 PM   #5
yzf219
Thanks. I want to upgrade because I don't like the slop in the factory mounts. Although those solid mounts are probably too extreme for me.
Old 10-05-2020, 05:24 PM   #6
DarkPira7e
DarkPira7e's Avatar
You'd be surprised where "slop" starts and ends. This is what I would do - get white line outrigger bushings and a transmission mount insert from whatever company you like, and see how much it helps.
If you're running a tune from someone, the tune can also affect how poorly the car runs- on/off throttle bucking can be aggressive timing swings or bad fueling.
I'll be frank- my car felt like crap, I hated how it felt during on/off throttle transition. During my car's downtime, I bought an STI transmission mount, torque solutions motor mounts, a carbon fiber driveshaft, all new suspension, sti top hats for the struts, subframe bushings inserts, and the outrigger diff bushings.
I hate drivetrain slop so much, I understand where you're at. I put solid transmission mounts on my car and it helped a lot, but solid mounts aren't good for a daily.
Try what I suggested initially and report back when my car runs again, I'll be able to say if my $2,000 anti-slop project worked. I can only rest easy knowing that it will be better than a solid transmission mount. I will admit though, the solid transmission mount got rid of 70% of my gripes
Here's my comparison-
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Bonburner (10-29-2020), MrSkubi (10-30-2020), Tanstin (11-03-2020), yzf219 (10-05-2020)
Old 10-05-2020, 05:37 PM   #7
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
OP. Just be careful, you can go too far and make for one uncomfortable ride in a DD. Ask me how I know on an 04 WRX. If it’s for track, well have at it.
Ernest72 is offline   Reply With Quote
The Following User Says Thank You to Ernest72 For This Useful Post:
yzf219 (10-05-2020)
Old 10-05-2020, 07:32 PM   #8
Grady
Grady's Avatar
You say you want to upgrade but want to spend less than OEM mounts?
The Following 3 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (10-05-2020), FRSapex (10-21-2020), RToyo86 (10-05-2020)
Old 10-05-2020, 11:10 PM   #9
yzf219
Already have the transmission insert. Helped a ton. Diff inserts are on order. Thanks for the comprehensive answer.
The Following User Says Thank You to yzf219 For This Useful Post:
DarkPira7e (10-06-2020)
Old 10-05-2020, 11:12 PM   #10
yzf219
OEM mounts are $80 here. Upgraded mounts are about $300-$500. I was just wondering if there were any alternatives. I do not expect upgraded mounts to be less than stock replacements.
Old 10-05-2020, 11:15 PM   #11
yzf219
I just watched your video. My tach bounces exactly like yours from the driveline lash. Let me know how your project goes.
Old 10-21-2020, 11:54 AM   #12
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
I have used the Megan racing engine mounts for my car for years and been very pleased. They are still rubber but much stiffer than stock and they removed a ton of slop without causing too much nvh for daily driving.
Sent from my SM-N960U using Tapatalk
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
The Following 3 Users Say Thank You to TeutonicShift89 For This Useful Post:
Slade (02-22-2021), Tanstin (02-23-2021), yzf219 (10-21-2020)
Old 10-25-2020, 07:14 PM   #13
brilliantnerd2050
Drives: IDONT HAVEONE
Just remember, the cheap is expensive sometimes.
brilliantnerd2050 is offline   Reply With Quote
Old 02-21-2021, 08:05 PM   #14
Slade
Slade's Avatar
Drives: 14 Limited BRZ
my mounts on my 2014 are bad. I'm looking to get new ones, but I don't want any NVH so Cusco and Perrin are out for me. I was told if you have mods you shouldn't get oem mounts. Looking at the Megan racing as I like the price and a poster above said he got minimal NVH, but I'm not sure Megan doesnt have the best reputation. I wanted the STI, but they seem to be sold out everywhere. Can anyone recommend me some mounts? what about Torque Solution? is that a quality brand? Thanks!
Slade is offline   Reply With Quote
Seized Motor - Need options/help GWiZ Issues | Warranty | Recalls / TSB 33 03-13-2015 05:36 PM
Notebook Mount Options JPxM0Dz Electronics | Audio | NAV | Infotainment 2 08-29-2014 08:54 AM
Top mount/camber plate options for KW V3? owenxguo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-21-2014 10:28 PM
My cheaper/simpler tranny mount xDanger_208x Engine, Exhaust, Transmission 6 11-03-2013 02:04 PM
Cheaper audio upgrade options. FReSh Electronics | Audio | NAV | Infotainment 9 02-22-2013 03:12 PM
