Old 10-04-2020, 11:11 AM   #1
Quicksilverfrs
Drives: 2014 Firestorm FRS
Need expertise advise, wrecked wheels
Hello,
I currently got into an accident and bent both my RPF 1’s beyond repair. They were 18x8.5 + 35 offset, matte black and unfortunately that size has since been discontinued. 2 out of 4 wheels/tires are still in good shape. What are my options? Trying not to buy all 4 new rims + Tires at the moment so I was thinking of doing a staggered set up.
Currently the closest size I can get to the same wheel is 18x9 +40 offset. Would that work? Worried it might throw the ABS sensors. Thanks!
Quicksilverfrs is offline   Reply With Quote
Old 10-04-2020, 12:48 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
https://www.ft86club.com/forums/showthread.php?t=67345
Different sized tires can throw all kinds of stuff off on these cars.
If money is an issue, find some stockers for stupid cheap and run those till you can get a proper replacement set, or buy all 4 now.
Old 10-04-2020, 12:50 PM   #3
ls1ac
ls1ac's Avatar
When buying the tires, make sure the diameter (or Hight) are the same and the ABS will not care.
Old 10-04-2020, 11:43 PM   #4
HaXx
Drives: jrsc_brz
Originally Posted by Quicksilverfrs View Post
Hello,
i rock two different color wheels, bought them that way, my last set was black/gold too. just saying
when your fronts are different color than the rears, it looks ratchet/drift setup. dont like that. but when the lefts are one, and rights are another, 1/10 people notice you have 2 different color wheels.
can you get an rpf1 in that size at all anymore, in a different color??
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Ohio Enthusiast (10-05-2020)
Old 10-05-2020, 10:15 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For an additional cost I would consider having the replacement wheels powder coated black to better match what you have.
RToyo86 is online now   Reply With Quote
Old 10-05-2020, 07:07 PM   #6
glhs386
Drives: 2014 FR-S Monogram
Buy the 18x9s and use them on the rear with the 8.5s in front. Run a 245/35/18 tire on all four corners, the rears will have a very mild stretch versus the fronts but it will be barely noticeable. You won't be able to rotate, but it's the best solution short of buying a whole new set of wheels.
glhs386 is offline   Reply With Quote
Old 10-06-2020, 12:29 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
I'd rather try to get square width, other pair also 8.5, even if of different offset. Some offsets can be "fixed" using spacers. Would hate to get extra understeer from staggered setup.
Just ordered a set of 18x9.5 +45 wheels, need suspension advise stlgrym3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2018 11:15 PM
Need your expertise(clutch and tranny) WatchmaN Issues | Warranty | Recalls / TSB 18 12-31-2014 09:32 AM
Advise Needed Wheels USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 10:39 PM
Made my drama on the FRS side, want some Subaru expertise and feedback. alrashwa BRZ First-Gen (2012+) — General Topics 30 01-15-2013 03:25 PM
