Old 11-16-2018, 05:28 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Just ordered a set of 18x9.5 +45 wheels, need suspension advise
Currently I’m running RCE Yellow springs on factory shocks, I was told in order to fit the new wheels I would have to go with coilovers in order to have space to clear the wider wheels. Is this true? If so will Tein Flex Z provide ample room?
stlgrym3 is offline   Reply With Quote
Old 11-16-2018, 05:39 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This is true: You need coils to fit 18x9.5 +45 wheels. And yes the Flex Z will work for what you need. They were on my list while I was shopping for coils. They get good reviews.
I LIKE TIRES!
Old 11-16-2018, 05:44 PM   #3
stlgrym3
Anyone cross shop Tein Flex Z with ST coilovers? Similar price, I’ve told ST are ore comfortable but no custom damping adjusments. Flex Z has custom damping but tend to make noises?
Old 11-16-2018, 09:19 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I have 18 X 9.5 +38, at +45 you'll need coilovers. It's because the spring perch is too wide and you'll be rubbing it.
I have tein flex A which is the same thing as Flex Z just a Hydraulic Bumpstop, and you'll have enough clearance. You'll also be able to run 255 35 tires no problems. 265 is when you'll start rubbing.
N1rve
Old 11-16-2018, 09:50 PM   #5
stlgrym3
For 17x9 +35 wheels and 245/40/17 tires, can i stay with my current suspension setup of RCE Yellow springs and stock shocks?
Old 11-16-2018, 10:15 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes.
I LIKE TIRES!
FINALLY ordered new wheels for my 10 Series! Nickel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-09-2017 09:57 PM
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 08:29 AM
Kiwami 18x9.5 all round. Stock Suspension sNake89 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-16-2016 06:30 AM
18x9.5 et 40- temporary on stock suspension? spacers? mkivalex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-25-2014 08:36 AM
Advise Needed Wheels USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 09:39 PM
