Old 09-25-2020, 08:49 PM   #1
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Oil leak
Hey guys, so I’m near the time for a new oil change, unfortunately my car started making some weird noises and making some weird vibrations. I checked my oil and there was hardly anything in there. There is a small sign of a leak on the driver side near the bottom but nothing significant. I’ve also looked up major signs of an oils leak and none of the symptoms match up. I did get a check engine light and the code read C000A i believe.
I did have an oil control valve replaced when i first bought the car, but other than that i haven’t had any bad luck with the car (knock on wood).
Has anyone experienced anything like this? Any help would be greatly appreciated.
Twitchy313 is offline   Reply With Quote
Old 09-25-2020, 09:15 PM   #2
Tokay444
Is the first time you checked the oil at the end of the interval?
Old 09-25-2020, 09:19 PM   #3
humfrz
Well, first off, Twitchy313, I suggest you push your car onto a level spot and check the oil level again, reading both sides of the dip stick.
If you change your own oil, now would be a good time to do it. Measure the amount of old oil that comes out of the crankcase. Refill the crankcase.
If you don't change your own oil, add oil till the dipstick reads full.
Start it up and check for any codes.
Report back. Maybe you got lucky.
Twitchy313 (09-25-2020)
Old 09-25-2020, 10:53 PM   #4
Twitchy313
Twitchy313's Avatar
I checked it about a week ago, when it started making noise. I noticed there was hardly any oil, so i added a bit but it seems to be burning through it pretty quickly.
Old 09-25-2020, 10:57 PM   #5
Twitchy313
Twitchy313's Avatar
Thanks @humfrz, i really hope i did lol. I don’t see a mess so that’s a good thing but i just find it very odd. And since i replaced the oil control valve once i figured it might need another change.
Old 09-25-2020, 11:13 PM   #6
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
How much is a "bit"?
PetrolioBenzina is offline   Reply With Quote
Old 09-25-2020, 11:20 PM   #7
Twitchy313
Twitchy313's Avatar
Not a lot, less than half a quart.
The Following User Says Thank You to Twitchy313 For This Useful Post:
humfrz (09-25-2020)
Old 09-25-2020, 11:24 PM   #8
PetrolioBenzina
Drives: 17 86
So you are still running four quarts low? If so, you need more oil ASAP, like before you drive it again. No oil as in nothing on the dipstick?
Old 09-25-2020, 11:38 PM   #9
humfrz
Where has your oil level been appearing on the dipstick, if at all?
Now, where is the oil level appearing on the dipstick (in reference to the holes in the dipstick)?
If your car is using a lot of oil, I doubt that it's "burning" it - unless you have oil dripping from the exhaust tips and blowing a huge cloud of smoke out the exhaust.
If it's leaking that much oil, it should be evident by looking for drips under the engine and/or a puddle of oil under the car.
Come back.
JesseG (09-30-2020)
Old 09-25-2020, 11:49 PM   #10
Twitchy313
Twitchy313's Avatar
Yea i was hesitant to add more oil before i found the leak if any, the last time i did my oil change there was a lot oil still. Now there’s less that the second dot on the dipstick
Old 09-25-2020, 11:54 PM   #11
PetrolioBenzina
Drives: 17 86
Anywhere between the dots is normal. You need to keep it there until you find the leak.
The Following 3 Users Say Thank You to PetrolioBenzina For This Useful Post:
humfrz (09-26-2020), JesseG (09-30-2020), Twitchy313 (09-26-2020)
Oil leak help please TorontoNat Engine, Exhaust, Transmission 1 12-26-2018 01:36 PM
Oil Leak Adamf220 Issues | Warranty | Recalls / TSB 11 05-04-2018 02:51 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 07:08 PM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
