Old 12-26-2018, 01:30 PM   #1
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Oil leak help please
The car runs fine, doesn’t overheat but the smell is pretty bad after long ish drives and there is obviously oil there but not sure at all where it could be coming from. The level seems to not move but I am definitely burning oil when I’m driving. Here is a picture, Any help is greatly appreciated, thanks guys, merry Xmas!
http://imgur.com/vwbp26E
"Enjoying Performance because of it's nature not because of it's quantity''
TorontoNat is offline   Reply With Quote
Old 12-26-2018, 01:36 PM   #2
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
It's either leaking from the bottom of your timing cover or your dipstick tube. Take off the under tray and have a look. Common thing with these cars, so don't worry too much. The smell is the oil dripping onto your header and burning. The reason you're likely not seeing the oil level change is most timing cover leaks (with a few exceptions) tend to only sweat a little bit of oil when the car is running.
MCTeeJ is offline   Reply With Quote
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil Leak Adamf220 Issues | Warranty | Recalls / TSB 11 05-04-2018 02:51 PM
Oil leak GsxrMe Forced Induction 4 12-18-2015 08:23 PM
Yet another oil leak.... Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-24-2015 01:02 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
