Old 09-25-2020, 03:32 PM   #1
Cae2444
Drives: 2015 FR-s
Headlight bulb is H1, socket/housing is for H11?
I've had my FRS for about 6 months, one of the bulbs burned out so I opened them up for the first time. I find that the bulb connection itself is for an H1 bulb, but the housing on the back of the headlight where the bulb is inserted is for an H11. I have no idea how the bulbs were in their prior, but I can not get the H1 bulbs positioned in the headlights. I even went to Toyota and they were stumped. Any ideas?
Cae2444 is offline   Reply With Quote
Old 09-25-2020, 04:14 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Someone at some point rigged your car with ghetto HIDs probably. Sorry I don;'t have something more constructive to offer, but that's not factory hardware
Old 09-25-2020, 04:31 PM   #3
Cae2444
Drives: 2015 FR-s
Alright, so if that's the case, best solution? If I need to get both headlights completely replaced I'll do it, last resort of course but at this point it's completely inoperable in the dark.
Old 09-25-2020, 04:38 PM   #4
DarkPira7e
DarkPira7e's Avatar
You need to determine where the wiring was changed to know what you need to fix/replace. If it's a plug n' play conversion, you can buy a stock wiring harness and be good to go
Old 09-28-2020, 01:01 PM   #5
Cae2444
Drives: 2015 FR-s
Thanks for the advise.
https://parts.toyota.com/p/Scion__FR...U00304316.html
So with 2 of these above, even if I need to cut the original wiring, I should be able to just replace with this, plug in some H11s, and be good to go?
Old 09-28-2020, 04:14 PM   #6
DarkPira7e
DarkPira7e's Avatar
I would imagine, yes. Unless they spliced before those connectors. I'd really still advise bringing it somewhere so they can make a fair evaluation of it if you're not sure after seeing the wiring diagram. Can't hurt to be sure before spending $180 on wiring
Trd headlight bulb misterfly Cosmetic Modification (Interior/Exterior/Lighting) 4 05-09-2017 05:09 PM
headlight bulb FR-Sky Cosmetic Modification (Interior/Exterior/Lighting) 3 01-05-2016 03:14 AM
Which LED bulb/socket? whip DIY (Do-It-Yourself) Guides 5 09-04-2014 02:44 AM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-28-2013 11:00 PM
Can someone with a BRZ limited measure the foglamp size (housing not bulb) Norkoastal Cosmetic Modification (Interior/Exterior/Lighting) 0 08-27-2012 11:31 PM
