Old 09-16-2020, 05:20 PM   #1
arxm
Drives: 2013 FR-S, 2023 BRZ
Need Help With Bluetooth
Hey guys, this might sound strange but please bear with me.
I replaced my clutch 2 years ago and after I replaced it I started having weird issues when outside temps were around 10-15 degrees C my bluetooth would start cutting out. Basically in the spring it happened a lot then went away.
I know its not my phone since I use bluetooth headphones for hours a day and never had it cut out like it does on the car. My first thought was a bad ground on the head unit which might have happened when i put everything back together from doing the clutch but when im using aux I have no issues.
After a LOT of trouble shooting ive found the issue to be some sort of harness in the center console right above the transmission tunnel, when I was test playing a song and started playing with this harness the audio started to cut out. One of the wires from this harness goes to the 12v outlet in the center console, is it possibly a bad ground to a bluetooth receiver antenna?
Im slowly losing my mind because anything I google just shows me either bluetooth to fm transmitters or like fuse box diagrams.
does anybody either 1) have a wiring diagram for whats in the center console or 2) know where the factory bluetooth receiver is
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 09-24-2020, 07:56 PM   #2
arxm
bump cuz im losing my mind trying to fix this
Old 09-24-2020, 08:51 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Oem stereos are dog shit.
You have to delete your phone data on the stereo. Re-pair it like the first time.
That the fix. You might have to do that again cause oem head units have Alzheimer's
I need help with bluetooth tmcmullins Electronics | Audio | NAV | Infotainment 10 07-06-2013 12:21 AM
Bluetooth Mic DatDudeLoso Electronics | Audio | NAV | Infotainment 4 01-17-2013 08:51 PM
Bluetooth grgonium CANADA 22 10-24-2012 12:52 AM
Bluetooth/Nav inimitable Electronics | Audio | NAV | Infotainment 40 09-26-2012 08:35 PM
FRS bluetooth set up jym89709 Electronics | Audio | NAV | Infotainment 16 09-08-2012 03:04 PM
