Old 09-06-2020, 02:44 AM   #1
gujianping88@hotmail.com
Drives: 86
86 trunk lid hard to close
Hi, everyone
Just find out 86 boot lid hard to close.
Anyone know how to fix it?
Thanks
gujianping88@hotmail.com is offline   Reply With Quote
Old 09-06-2020, 04:21 AM   #2
humfrz
Grease the latch?
Adjust the latch?
I'll refer you to our trunk closing expert @Ultramaroon.
Old 09-06-2020, 10:43 AM   #3
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Define "hard to close". Mine takes a firm push.
PetrolioBenzina is offline   Reply With Quote
Old 09-06-2020, 03:10 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
The latch on the lid can be adjusted. Your second photo nicely shows the two screws that need to be loosened. Be careful. Once you loosen them, you're committed to making some sort of adjustment.
I've never had to do it so I can't advise with experience but the procedure is described at the bottom of this page. I'm not so sure about using a hammer. Seems excessive. :/
humfrz (09-06-2020), JesseG (09-08-2020)
Old 09-08-2020, 05:17 PM   #5
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Here's another solution:
https://www.ft86club.com/forums/show...7&postcount=30
LimitedSlip is offline   Reply With Quote
Old 09-08-2020, 06:14 PM   #6
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
It takes a little effort to close my trunk also. But in my case I have the extra weight of the TRD wing to help close it. Otherwise you have to firmly close it. No soft close doors/trunk on the twins!
JesseG is offline   Reply With Quote
Old 09-09-2020, 07:49 AM   #7
Not sure if applicable to the pre facelift cars in other countries but the 17+ models with the factory spoiler have a new damper installed. These require much more force to close than the ones without it. It isn't a matter of adjustment but simply pushing harder to counter the damper force.
JesseG (09-14-2020), saltywetman (09-19-2020)
Old 09-09-2020, 11:20 AM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes, applicable to pre facelift cars. Spoiler comes with new dampers.
JesseG (09-14-2020), Tcoat (09-09-2020)
Old 09-18-2020, 04:32 PM   #9
IvoryHammer
Drives: '17 BRZ PP
I've got the perf pack wing and it still take a good slam to get it closed. Really bothers me considering I recently drove a rental econobox hyundai that was soo much smoother and easier to close.
I think the thread LimitedSlip posted is the way to go, because it puts the striker in a better starting position. But, I'm curious how long the solution would last vs using a steel shim and some epoxy.
IvoryHammer is offline   Reply With Quote
2017 BRZ trunk hard to close? wild03 Issues | Warranty | Recalls / TSB 51 08-02-2021 11:21 AM
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
(Close)WTB:Aus GT Black interior(Close) Ry.ruzn Want-To-Buy Requests 0 04-20-2016 01:55 AM
Trading Carbon Fiber VIS Racing Trunk for Asphalt Grey Trunk + Cash asphaltkyle Exterior Parts (Aero, Lighting, Etc.) 19 10-13-2015 06:51 AM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
