Drives: 2013 Subaru BRZ
Push To Start not working
I have a 2013 BRZ with 160k miles on it. Every time I push the start button, the green key light starts flashing and will only go into on/accessories mode and won't start even with the clutch fully depressed. sometimes, after pressing the clutch down and clicking the start button multiple times it occasionally starts up. I have already replaced the clutch starter switch at the pedal and it seemed to help for a little bit but after about a week it started doing the same thing and has gradually gotten worse. anyone have a similar issue and got it fixed?
#2 | |
Drives: 22 BRZ limited
Will it start if you hold the fob to the start button? |
#3 | |
![]() Now, tell me you have replaced the batteries in the FOB? Tried another FOB? |
I have replaced the batteries on both fobs, and have held the key to the start button as well, woke up this morning and the car started first try but every once in a while it doesnt
Drives: Subaru brz 2016
Check your battery, if its worn that might be it. Should be around 13-14 volts fully charged.
Sorry for not replying sooner, my battery has tested fine. I’ve checked the alternator and starter and they are okay as well, it still goes to on, the accessory mode then off and I’m stumped on what it could be
Drives: Series Blue WRB JRSC C38 HBP Flex
Clutch safety switch?
#10 |
| Stall/No Re-start with push button start | couver | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-26-2020 10:32 PM |
| FS: STI engine start push start OEM plug and play | sokol | Interior Parts (Incl. Lighting) | 5 | 06-13-2019 02:12 PM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
