Old 08-19-2020, 06:02 PM   #1
wangmanlex
Drives: 2013 Subaru BRZ
Unhappy Installed New Clutch. P0011 Code Came On.
I’ve recently installed, with a help of few friends, a new ACT Clutch to my BRZ. We put everything back together and once we gave it a start the car started to idle very roughly jumping from 500 to even 2k rpms as if it was trying to stay alive. Shortly after it turned off as if it stalled. Friend turned it on again same issue and tried to go for a test drive. Car stalls every time it is put into neutral. Even while car is going downhill in neutral, same result. Later after the test driving the P0011 code shows up. We cleared it and tried again but same result. I’ve been digging around but still couldn’t find an issue related to my topic. I’m 80% sure the clutch install went right but as my experience for working on cars is little and is mostly leaned on another person my friends and I have no clue what happened. Any ideas? and please go easy on me
wangmanlex is offline   Reply With Quote
The Following User Says Thank You to wangmanlex For This Useful Post:
humfrz (08-19-2020)
Old 08-19-2020, 06:12 PM   #2
p1l0t
p1l0t's Avatar
P0011 is the camshaft position sensor. Do you have a code reader? It should tell you which bank/sensor it is.
Old 08-19-2020, 06:24 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
Broke a driver's side cam sensor doing my clutch 3 months ago, just snapped the plug off the end of it.
Amazon had me a new one in two days.
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
jcw99 (08-22-2020), p1l0t (08-19-2020)
Old 08-19-2020, 08:07 PM   #4
wangmanlex
I didn’t catch it. Friend just cleared the codes and it hasn’t came back since.
humfrz (08-19-2020)
Old 08-19-2020, 08:16 PM   #5
humfrz
Was beer involved in this committee operation?
You only need to have two people helping you - one to hand you tools and the other to run and get more beer.
That way if you screw something up, you'll know who did it.
https://www.autoblog.com/2016/03/25/...shaft%20timing.
Good luck getting it sorted out. I'll guess you knocked a connection lose.
p1l0t (08-19-2020)
Old 08-22-2020, 10:21 PM   #6
wangmanlex
Engine light came back on but for some reason we're unable to read or even connect using the OBD Reader we have. I've checked ohms readings on the crankshaft sensor and two camshaft sensors on the driver side. They're all working properly.
I forgot to mention this but the traction control light is also on. I've read around the forums of these symptoms happening to many others but for this to happen after we install a clutch? It's painful to say. Friend suggests I buy an Open Flash Tablet which I'd rather not do or just call this issue to Subaru...
I've had another friend suggest the clutch itself could be the issue whereas its throwing off the crankshaft position sensor in some way. Other than that I'm still stumped...
humfrz (08-22-2020)
Old 08-22-2020, 11:14 PM   #7
humfrz
I'd suggest you test your reader by hooking it up to another car. If it's bad, get a code reading with another reader.
Having the trouble code will be important in figuring out what is wrong.
Old 08-22-2020, 11:28 PM   #8
p1l0t
p1l0t's Avatar
Yeah that code will tell you a lot. A good reader can also get the history of recent codes as well. Also there are 4 cam position sensors and the crank sensor. Sounds like you still have 2 more cam sensors to check?
humfrz (08-23-2020)
Old 08-25-2020, 06:35 PM   #9
wangmanlex
I recently made a purchase of a reader my self and went to use it myself. Now after using the reader four codes have showed up....
P0102 - Mass or Volume Air Flow Circut Low Input
p0011 Intake Camshaft Position Timing- Over-Advanced (Bank 1)
p0021 Intake Camshaft Position Timing- Over-Advanced (Bank 2)
p0420 Catalyst System Efficiency Below Threshold (Bank 1)
So before I had scanned anything I took out the Crankshaft Position Sensor testing it for resistance and if it were still working. I decided to not put it back in and come back to it a later day. My friend decides to turn on my car in Accessory Mode, as the sensor is still not plugged in, to pump someone's tires as I have Air Suspension with a adapter to my tank. These codes were not there until the day of and was wondering what could've triggered this?
humfrz (08-25-2020)
Old 08-25-2020, 06:54 PM   #10
humfrz
YIKES! Something(s) is/are messed up but it's waaaay over my pay grade to figure out what.
Hopefully someone will come along soon to help you out.
Old 08-25-2020, 11:53 PM   #11
solidsnake11
Drives: brz
Well your friend might be partially right. Did you align the crank reluctor up with the small dowel? It is behind the flywheel.
As far as going easy on you, my grandfather said if you've never messed anything up you have never done anything.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
p1l0t (08-26-2020)
Old 08-26-2020, 06:24 PM   #12
p1l0t
p1l0t's Avatar
I feel like with all those codes the MAF would likely be the cause because it might cause the others but the others would probably not cause it. SO I would check the wire going to the MAF and/or test/replace the MAF. (Put your cranksensor back in first though)
clutch, p0011, rough idle
P0011 & P0021 BlueLine Issues | Warranty | Recalls / TSB 14 09-17-2020 09:02 AM
P000A and P0011 Riftur Issues | Warranty | Recalls / TSB 5 02-13-2017 09:32 PM
P0455 EVAP Code after New Direct and Port Injectors Installed? (Vortech Supercharger) Figo Forced Induction 8 10-04-2016 01:40 PM
car won't start after clutch installed aquaman Issues | Warranty | Recalls / TSB 4 07-19-2016 01:29 AM
Need clutch installed - recommendations midnight23 Southern California 2 08-07-2013 09:37 PM
