Drives: 2020 toyota 86
camber Confusion
If I use both upper and lower camber bolts, does that give me 3 degrees neg?/
Thanks |
Drives: 2013 WRB BRZ
Most people don't get to about -2.5*. The holes in the strut are 2 different sizes, so you can play with which one goes where to try to maximize negative camber.
See here: https://www.ft86club.com/forums/showthread.php?t=70035
Undisputed El Presidente
Drives: Zenki 37J ZN6
If the upper strut hole is slotted you might be able to get it
Drives: '13 Whiteout
-2 is about it. The camber bolts can slip out of alignment. Get camber plates
Drives: Subaru BRZ
never mind me. Posted this in the wrong thread. How? I don't know. Sent from my SM-G973F using Tapatalk Last edited by Purist; 08-20-2020 at 07:19 AM. |
No
Drives: Subaru BRZ
See previous admission of incompetence
Drives: 2022 BRZ sport-tech
I can't be certain with this platform but I ran 2 sets of SPC camber bolts on my 8th gen civic SI, they never slipped. This is with track use, winter driven with lots of raid salt, and long 10 hours road trips with about 30k miles of use over 4 years. Are bolts that prone to slippage on this platform? I am not a fan of camber plates because the spherical bearing on the upper plates always wears prematurely, especially for a car that sees winter abuse. And there are also reported case of upper camber plates slipping (perhaps brand specific?).
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#9 | |
unless you run an eccentric bolt in a slotted strut hole, then slipping is more likely. |
#10 |
Drives: 06 Exige, 17 BRZ PP
#11 |
Drives: 2017 BRZ series.yellow
#12 | |
Drives: 2018 BRZ
I'd wager that for a casual driver, even casual tracker, the difference in reality would be fairly minimal - just dial in the amount of camber that results in even wear/temperature across the width of the tread for your driving style and roads/tracks you drive on. If you're really serious about tracking, suspension tuning would be a whole lot more complicated anyway, and each way to change it would result in side effects that would need to be handled somewhere else - i.e. dial in the suspension with whatever tools you have so that the overall effect is what you need, regardless of the intermediate steps and their impact. |
#13 |
Drives: Crapcan
I have seen posts that say the opposite. I am sure the difference is negligible for most people.
| Oil Level Confusion | WC-BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 12-30-2018 01:46 AM |
| OFT CAL confusion? | Madara | Software Tuning | 5 | 08-04-2018 11:20 AM |
| Exhaust Confusion | Strife26 | Engine, Exhaust, Transmission | 8 | 05-03-2015 07:42 PM |
| SPC RLCA Confusion | EN2_Squirrel | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-28-2013 07:21 PM |
| Fog light confusion? | PurpleTerds | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-02-2012 11:07 PM |
