Old 08-19-2020, 05:52 AM   #1
54fighting
Drives: 2020 toyota 86
camber Confusion
If I use both upper and lower camber bolts, does that give me 3 degrees neg?/
Thanks
54fighting is offline   Reply With Quote
Old 08-19-2020, 07:37 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Most people don't get to about -2.5*. The holes in the strut are 2 different sizes, so you can play with which one goes where to try to maximize negative camber.
See here: https://www.ft86club.com/forums/showthread.php?t=70035
BigTuna is offline   Reply With Quote
Old 08-19-2020, 11:39 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If the upper strut hole is slotted you might be able to get it
strat61caster (08-19-2020)
Old 08-19-2020, 01:01 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
-2 is about it. The camber bolts can slip out of alignment. Get camber plates
TommyW is offline   Reply With Quote
Old 08-19-2020, 09:24 PM   #5
Purist
Purist's Avatar
Drives: Subaru BRZ
never mind me. Posted this in the wrong thread. How? I don't know.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 08-20-2020, 02:04 AM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No
ineedyourdiddly
BlueWhelan (08-20-2020)
Old 08-20-2020, 04:55 AM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
See previous admission of incompetence
Less More
Old 08-20-2020, 07:59 AM   #8
Petah78
Drives: 2022 BRZ sport-tech
I can't be certain with this platform but I ran 2 sets of SPC camber bolts on my 8th gen civic SI, they never slipped. This is with track use, winter driven with lots of raid salt, and long 10 hours road trips with about 30k miles of use over 4 years. Are bolts that prone to slippage on this platform? I am not a fan of camber plates because the spherical bearing on the upper plates always wears prematurely, especially for a car that sees winter abuse. And there are also reported case of upper camber plates slipping (perhaps brand specific?).
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-20-2020, 12:46 PM   #9
finch1750
finch1750's Avatar
no, they arent. but they can. just check them on occasion and its fine.
unless you run an eccentric bolt in a slotted strut hole, then slipping is more likely.
NoHaveMSG (08-20-2020)
Old 08-24-2020, 02:06 PM   #10
Evan55
Drives: 06 Exige, 17 BRZ PP
Get both. Camber at the hub is better than camber at the strut top.
Evan55 is offline   Reply With Quote
Old 08-25-2020, 12:41 AM   #11
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
I'll have to disagree with that. Specifically for the front setup with mac struts. More camber created at the top hat will yield better dynamic camber while cornering.
Breezio is offline   Reply With Quote
Old 08-25-2020, 08:58 AM   #12
Ohio Enthusiast
Drives: 2018 BRZ
I'm far from a suspension expert, but from my understanding the main issue with camber plates is that they change the overall geometry of the front end, affecting not only the camber but also SAI, roll center, etc. vs. camber bolts (or other hub based adjustments) which almost exclusively change camber alone.
I'd wager that for a casual driver, even casual tracker, the difference in reality would be fairly minimal - just dial in the amount of camber that results in even wear/temperature across the width of the tread for your driving style and roads/tracks you drive on.
If you're really serious about tracking, suspension tuning would be a whole lot more complicated anyway, and each way to change it would result in side effects that would need to be handled somewhere else - i.e. dial in the suspension with whatever tools you have so that the overall effect is what you need, regardless of the intermediate steps and their impact.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Breezio (08-26-2020)
Old 08-25-2020, 09:30 AM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have seen posts that say the opposite. I am sure the difference is negligible for most people.
Oil Level Confusion WC-BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 12-30-2018 01:46 AM
OFT CAL confusion? Madara Software Tuning 5 08-04-2018 11:20 AM
Exhaust Confusion Strife26 Engine, Exhaust, Transmission 8 05-03-2015 07:42 PM
SPC RLCA Confusion EN2_Squirrel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-28-2013 07:21 PM
Fog light confusion? PurpleTerds Scion FR-S / Toyota 86 GT86 General Forum 5 08-02-2012 11:07 PM
