Old 08-13-2020, 05:50 AM   #1
DubBoomin
TEIN Street basis Z, not satisfied, want to go lower
I got TEIN street basis z coilovers for my 13 Scion FR-S and I’m not satisfied with how low they go. Is there anyway I can make them go lower and how? The coilovers aren’t maxed out because when I max them out the springs move around and I’m not sure if that’s normal or not.
DubBoomin is offline   Reply With Quote
Old 08-13-2020, 02:35 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
To get a lower look get more rubber. Lower control arms work too. I have the street basis z and plan on upgrading because they are bumpy and with going lower i would want to set damping which you can't with these teins. My car is almost maxed out. The front could be better but because of the roads and no damping I won't risk it.
My setup is: 18x9.5 +35 on 255/35/18 no rub. Still need to do an alignment tho. Lol.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following User Says Thank You to Joveen For This Useful Post:
DarkPira7e (08-14-2020)
Old 08-14-2020, 04:06 PM   #3
strat61caster
strat61caster's Avatar
If you want the looks without spending the money and don't give a shit about ride quality then slam the coilovers. You won't die because the springs are loose when the car is in the air.
Drive safe.
ineedyourdiddly
Old 08-15-2020, 02:34 AM   #4
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
What is your drop in inches from stock, if you don't mind me asking?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
ST vs Tein Street Basis Z RustyS14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-29-2017 01:34 AM
Tein Street-basis Slammillionaire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-26-2017 04:15 PM
(LA/OC) FS: Tein Street Basis xais Brakes, Suspension, Chassis 1 05-05-2016 06:07 PM
Tein Street Basis dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2015 07:40 PM
Tein street basis, not satisfied, want to go lower Vancityfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-06-2015 07:11 PM
