Old 11-28-2017, 09:00 PM   #1
RustyS14
ST vs Tein Street Basis Z
Sorry to clog the forum with yet another coilover comparison thread but I searched and couldn't find what I was looking for. I recently sold my S2000 and picked up a 13 BRZ limited. The car is bone stock other then some eibach sportline springs that were installed by the previous owner. While I like the look of the car with the eibachs, both of the rear struts are blown so I figure its time to look into something else.
Right now I'm torn between the Tien Street Basis Z and the ST coilovers. I've read good reviews for both but am not sure which one would best suit my usage. The car is meant to be my new DD but I will try to do at least 1 HPDE event per month in the spring-fall so the car will see some track usage. I realize that both options will likely be under-dampened for the track but ride quality is my main concern here. I assume that the Tiens will be a bit stiffer than the ST setup since the spring rates are a tad higher but has anyone on here rode in both that can comment? I've narrowed it down to these two sets since they're the only two brands that I trust with offerings in the sub 1k price point. I'm not opposed to getting a spendy set in the future but I don't want to sink too much into the car right now since I'm not yet 100% sold on keeping it long term.
FWIW I will not be lowering the car anymore then it currently sits on the sportlines and am running 17x9 +35 RPF1s with245/40/17 Star Specs all around (I assume I won't run into any clearance issues since they fit fine with the stock struts). I will also be installing a Whiteline roll center kit, SPC control arms and front crash bolts when I do the coils but don't plan on doing much else to the car.
RustyS14 is offline   Reply With Quote
Old 11-28-2017, 09:11 PM   #2
Teseo
Drives: frs
You looked for the flex z? Price range as ST, but thanks for creating this thread Because im on same boat. But i guess im going with ST route for the reasson of install and forget
Old 11-28-2017, 09:22 PM   #3
RustyS14
I looked into the Flex Z but I guess I'm getting older and don't want pillow ball mounts on my daily anymore lol. Plus I don't plan on lowering the car much so I don't need a full tap coilover. I'm also leaning toward the ST setup but I'm totally new to this chassis so I'm not sure if there is anything that I'm missing.
Old 11-28-2017, 09:24 PM   #4
Teseo
Drives: frs
[COLOR=inherit !important]
#s3gt_translate_tooltip_mini { display: none !important; }
[/COLOR]
With flex z you can adjust the dampening (soft/stiff)
Old 11-28-2017, 10:00 PM   #5
monkeybike
Drives: 86
Maybe consider upgrading to Koni or Bilstein strut and shocks instead for the same price if you are happy with the springs?
http://www.ft86speedfactory.com/susp...ks-struts.html
monkeybike is offline   Reply With Quote
Old 11-28-2017, 10:09 PM   #6
Lust
Drives: 2017 Subaru BRZ
Take a look at the Tein Flex Z and CSG spec Flex A. Currently the best on the market for their price point. Shoot me a PM if you have questions
Lust is offline   Reply With Quote
Old 11-28-2017, 10:28 PM   #7
RustyS14
Honestly that probably would be the logical thing to do. What I like about the coilover options is that both KW and Tien have matched their dampers to the springs on the coilovers. The spring rate on both coilovers is similer to the rates I found for the eibachs (ST is actually the same) so I would hope that the coils would ride better then a mismach spring/strut combo. I may be overthinking it though...
Old 11-28-2017, 10:36 PM   #8
RustyS14
The CSG Flex A is an interesting setup, I'll have to look into them a bit more. They are a bit more spendy then I was looking for but my interest has been piqued lol.
Old 11-28-2017, 11:18 PM   #9
Lust
Definitely send CSG a PM. Let them know I referred you and they’ll be able to get you sorted no matter what you decide on
Old 11-29-2017, 02:34 AM   #10
strat61caster
strat61caster's Avatar
I think you're overestimating how much effort some companies put into their ~$1k offerings.
ineedyourdiddly
Tein Street-basis Slammillionaire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-26-2017 05:15 PM
(LA/OC) FS: Tein Street Basis xais Brakes, Suspension, Chassis 1 05-05-2016 07:07 PM
Tein Street Basis coilovers Amuse_S2000 Brakes, Suspension, Chassis 8 12-21-2015 12:49 AM
Tein Street Basis dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2015 08:40 PM
NY: F/S Tein Street Basis jammz Brakes, Suspension, Chassis 5 04-20-2013 10:31 PM
