Drives: TRD R.S. 1.0 FRS
EBCS disabled after wideband wiring?
Car is turbo-ed with Works stage 2 turbo kit. Has a Ptuning EBSC was working great before i did all the wiring for my wideband for ecutek to log it.
It seems like after i wired the WB into my evap signal the boost controller either has been disable or doesnt work because i haven't seen boost over ~7psi (wastegate pressure). i have maps thats good for 8 and 10 psi. First time with the WB wired up to ecutek, it posted CEL P0452, P1449, P0453. These were later disabled in the tune by the tuner and now it post P0451 intermittently. Got another tuned with it disabled. will report if that fixed my issues. Has anyone got any of these issues or have any ideas for solutions? More than likely ill just undo all my wiring since its messing with an important piece of my setup. any help would be appreciated. |
#2 | |
Drives: Whiteout FRS
Might also want to try putting this in the forced induction section. If anyone else thinks I am wrong, please correct with proper info. |
#3 | |
Turns out it was just the tune. Wiring was fine, i did double check them. I think my tuner re-scaled the maps. Everything is working fine. Wideband and ecutek logs are pretty dead on now. |
| The Following User Says Thank You to airrick For This Useful Post: | Bach415 (08-17-2020) |
| Replacing & wiring AEM wideband | sqd | Engine, Exhaust, Transmission | 1 | 05-14-2019 03:05 PM |
| Wiring wideband to ECU | Toyota GT 86 | Electronics | Audio | NAV | Infotainment | 2 | 03-14-2017 08:22 PM |
| EBCS, Wideband and Flex... | Shady195 | Software Tuning | 11 | 02-27-2017 02:40 PM |
| Wideband LC-1 wiring. | MattF | Forced Induction | 9 | 07-09-2013 09:33 AM |
| Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
