Old 08-08-2020, 01:08 AM   #1
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
OLM / Vland Headlights: turn signal flashing from boomerang
Firstly, I’ve had the headlights installed for only a few days now and everything was working fine as of today. It was only as I was driving home that I realized the turn signal was flashing from the boomerang. I switched some of the connectors, thinking maybe I connected them backwards and forgot, but nothing. I have no idea where to start and I really don’t want to pull off the bumper again.. help me please..
Edit:: crappy splice job on turn signal. Respliced all the connections and it’s fixed.
Here’s a video if you care to see.
I'd change the world if I could change my mind
DaveFTW is offline   Reply With Quote
Old 08-08-2020, 01:23 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
One side is working correctly, so make sure the harnesses are identical--bilateral comparison. You shouldn't need to remove the bumper to look at the back of the headlights.
VLAND turn signal wiring help needed quick Sam86 Cosmetic Modification (Interior/Exterior/Lighting) 14 06-30-2020 10:38 PM
Help* VLand Hesdlights turn signal issue bxnkz Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2020 01:45 PM
VLand Headlight Turn Signal Issue? Scjacob827 Cosmetic Modification (Interior/Exterior/Lighting) 3 05-20-2019 09:14 PM
Fine looking Intec turn signal flashing Fender vent bryan0101 Cosmetic Modification (Interior/Exterior/Lighting) 23 01-26-2016 10:43 PM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
