Old 05-19-2019, 08:19 PM   #1
Scjacob827
Drives: 13' BRZ
VLand Headlight Turn Signal Issue?
So I recently installed my new VLand headlights and everything worked great, aside from the boomerang? Should I look into replacing the DRL relay because I put all new bulbs in the headlights and nothing. A few days went by after the install then my turn signals stopped working! My hazards still work so I know its not the bulb. So now I'm thinking I need to replace that fuse possibly, but its just weird that my hazards still function.
Any help is much appreciated!
Scjacob827 is offline   Reply With Quote
Old 05-20-2019, 02:18 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Are you using the oem turn signal flasher?
Old 05-20-2019, 09:17 AM   #3
Scjacob827
Drives: 13' BRZ
I believe the VLands came with a turn signal bulb already and I just ended up getting my own Headlight bulbs. So I am using the turn signal bulb they provided.
Old 05-20-2019, 09:14 PM   #4
soundman98
soundman98's Avatar
they should be an led signal. the oem turn signal flasher is designed to be used with incandescent bulbs.
many retailers include a replacement led-compatible flasher, otherwise, they're not too hard to order.
i suggest you change your flasher relay with an led compatible model before going through any more troubleshooting.
TOMs & turn signal issue Powered By Jay Cosmetic Modification (Interior/Exterior/Lighting) 19 01-14-2015 11:33 PM
OLM turn signal switchback issue Scavanger Scion FR-S / Toyota 86 GT86 General Forum 5 09-17-2014 11:42 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 12:47 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
