Old 08-07-2020, 05:30 AM   #1
mg92p
Drives: Subaru BRZ S 2013
Difference between ID1050 and DW700 Injectors
Hi All,
Am now collecting parts to go FI with my BRZ.
Cant find an answer on the differences/benefits between the ID1050 and DW700 fuel injectors. Would anyone be able to enlighten me?
OTHER INFO: I am looking to make 300ishwhp on E85 (flex fuel) for now.
Cheers
mg92p is offline   Reply With Quote
Old 08-07-2020, 05:34 AM   #2
TurboBRZ_UAE
Drives: 2015 GT86 SC; 2014 BRZ turbo (sold)
Capacity wise, both should do for pump gas. Not sure on e85.
I leaned toward ID1050's for my build - have heard multiple tuners say that they are more consistent, making for easier tuning. Especially so at low duty cycle.
The ability to replace an injector with a match which had been flow tested is a bonus for down the line
TurboBRZ_UAE is offline   Reply With Quote
The Following 4 Users Say Thank You to TurboBRZ_UAE For This Useful Post:
DarkPira7e (08-07-2020), Irace86.2.0 (08-07-2020), Joveen (08-07-2020), mg92p (08-07-2020)
Old 08-07-2020, 06:13 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The real advantage of the 1050x is the ease of tuning and response.
I would go with the 1050x just to make your build that much more reliable. Also, DW injector harnesses are frail.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Old 08-07-2020, 03:01 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
As far as capacity, I have the DW700s on E85 at 12psi with plenty of headroom. Even though the ID1050s are 50% more expensive, the actual price difference isn't much in the grand scheme, so if I had done my research then I would have done the ID1050s. At the time, I was thinking they were overkill, such that, I figured low-speed, low-duty modulation would be harder and less consistent like trying to blow out candles on a birthday cake with a leaf blower.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
mg92p (08-07-2020)
Old 08-07-2020, 03:15 PM   #5
ID1050X's have a better spray pattern and atomization, as well as more consistency. They can take low pulse widths completely accurately and will idle port only without issue.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
airrick (08-07-2020), DarkPira7e (08-07-2020), Irace86.2.0 (08-07-2020), mg92p (08-07-2020), tomm.brz (08-07-2020)
Old 08-07-2020, 03:39 PM   #6
Irace86.2.0
This is the counterintuitive part that makes doing your research before you buy important. For the extra couple hundred bucks, it is really a no brainer on something that is as important as tuning, safety, etc.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
Chuckls (08-20-2020), CSG Mike (08-07-2020), tomm.brz (08-07-2020)
Old 08-07-2020, 09:10 PM   #7
zberz
Drives: 2015 Lightning Red BRZ
I bought the ID1050s at the recommendation of my tuner. I can't say how well they perform because I haven't gotten tuned yet. I have no experience with the DW injectors, but I can say you'll need adapters for the ID injectors. Don't buy the hard plastic ones (like I did), they don't fit under the stock injector covers.
Sent from my SM-G950U using Tapatalk
zberz is offline   Reply With Quote
The Following User Says Thank You to zberz For This Useful Post:
mg92p (08-07-2020)
Old 08-08-2020, 07:32 AM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I also use the ID1050's based on the recommendations from my tuner as well. He also recommended the Full Blown Walbro 485 fuel pump kit.
BirdTRD is offline   Reply With Quote
Old 08-08-2020, 10:39 AM   #9
byun
byun's Avatar
Drives: 2015 BRZ CWP
I would have bought the 1050x if they were out when I got the DW700s. Ive been running for the DW’s for years on track with no issues and currently running E85 at 16psi and had no issues. Guess picking the right tuner helps too.
byun is offline   Reply With Quote
Old 08-08-2020, 08:43 PM   #10
Irace86.2.0
Yes, this is what I was told too, that they are better, but the DW one's are fine. Specifically:
The people that say the ID1050's are easier to tune are people that read off an excel spreadsheet the values they need to put into the software to make the tune work. I believe most tuners do not use the DW700cc injectors because honestly they do not know how or do not want to spend the time to figure them out. So they would rather just use what is easy.
Now I will see the ID1050 injectors are a great injector but you are paying a lot more for something you really do not need. We have tuned literally thousands of DW700 injectors on this platform and the failure rate on them is insanely low.
Even with that said, the ID ones aren't much more, so why not? Obviously if they are not available then that is that.
Old 08-10-2020, 03:50 PM   #11
Most folks, including CSG, should be selling them with pigtails.
zberz (08-10-2020)
Old 08-10-2020, 05:37 PM   #12
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I used DW700's and made 300whp with E85 with never an issue in ~5 years.
cruizin01 is offline   Reply With Quote
Old 08-10-2020, 06:56 PM   #13
zberz
Rallysportdirect did not. Let this be a lesson to all of us cheap bastards who save $50 buying injectors but then spend another $80 trying to get them to work. My money will go to you next time.
Old 08-10-2020, 09:20 PM   #14
DarkPira7e
DarkPira7e's Avatar
I use piece of shit used 04 STI injectors and made 330whp on 93. It's not that it doesn't work, it's that it can always we better. For some of us, "better" is something not worth chasing for what we may see as a marginal quality of life improvement.
I agree that those viewing this thread shouldn't think "1050x or GTFO". Hell, I have a cxracing $199 dollar turbo that runs great too. And I don't use a BOV! There are far BETTER choices to be made, but they work well enough for me and that's what counts, really.
The 1050x is just a top tier choice for quality of life with tuning. If I spent money on injectors, honestly I'd probably go with them just to see for myself what the benefits are.
Difference Between V2.076 and V4.03 NyX_Nick Software Tuning 2 06-01-2018 10:00 AM
What's the difference DarkSideFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-09-2018 09:12 AM
bra difference from frs shift2launch BRZ First-Gen (2012+) — General Topics 5 01-22-2015 01:00 AM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
LED vs HID: what's the difference? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 13 04-06-2013 07:23 AM
