Old 07-25-2020, 10:06 AM   #1
bigfatcat
bigfatcat's Avatar
Drives: gt86
Do I need to change bolt and seal for Perrin crank pulley install
Bought a Perrin pulley. I found this install video where he says you need to replace the seal and bolt during install. He also torqued it like crazy with a breaker bar to the point that the bolt is wobbly when the car is on.
Wondering is this the right way to install it? Or should I just follow the instructions that came in the box? Do I need to replace bolt and seal? Thanks
bigfatcat is offline   Reply With Quote
Old 07-25-2020, 10:45 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Technically, it is a stretch bolt and should be replaced.
That being said, I have used the same bolt 3 times now. If your car is high mileage, I would probably go ahead and replace the seal while you are there. If it looks good and is not leaking don't worry about it, just be mind full of the seal when installing. And torque it properly.
Old 07-25-2020, 03:56 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
change pulley for a stock one
Old 07-26-2020, 03:22 AM   #4
bigfatcat
bigfatcat's Avatar
Drives: gt86
Thanks. I looked through the manual for that section.
The manual mentions the
-timing belt housing seal
-spacer o ring
-bolt.
It says to put in a new spacer o ring. But it didn’t say if the seal and bolt need to be replaced or can be reused.
Old 07-26-2020, 08:19 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's worth the pocket change to just replace the bolt. No sense in taking a risk when it's 100% avoidable
Old 07-26-2020, 01:15 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is what I did. The Perrin one is now a paperweight on my desk.
Old 07-26-2020, 01:32 PM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
-spacer o ring
-bolt.
You don't need a new bolt, but it is a good idea to install a new one if you have a highly mileage car.
Old 07-26-2020, 04:12 PM   #8
bigfatcat
bigfatcat's Avatar
Drives: gt86
Just curious Why did u go back to the stock one?
Old 07-26-2020, 06:47 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Switched to stock to see if I could tell a difference. Couldn't so left it on.
Old 07-26-2020, 10:22 PM   #10
Ultramaroon
not playing cards
-spacer o ring
-bolt.
All kidding aside...
The main screw is perfectly fine. Mileage has absolutely nothing to do with it. There is an important section in all good documentation that explains how to use it. A common convention is that black dot. In the exploded parts diagrams, all items can be considered reusable unless expressly indicated by that symbol.
Old 07-27-2020, 12:00 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think I misinterpreted the torque+angle spec as being a stretch bolt. I guess necessarily it doesn't have to be. The manual does indeed show it is reusable
Old 07-27-2020, 01:12 AM   #12
Ultramaroon
not playing cards
It's all good. Had to double-check it for myself.
Old 07-27-2020, 01:23 AM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes the manual says it is reusable. It doesn't say anything about high mileage. I just prefer to change bolts in such kind of components for the peace of mind.
Old 07-27-2020, 12:01 PM   #14
Jdmjunkie
Drives: Scion FR-S 10 Series
Arp also makes a replacement crank bolt.
Jdmjunkie is offline   Reply With Quote
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
DIY - Lightweight crank pulley install (Perrin) justinco DIY (Do-It-Yourself) Guides 11 05-22-2017 04:35 PM
Perrin Crank Pulley Install (time lapse vid) ninjasaurusrex DIY (Do-It-Yourself) Guides 0 03-12-2014 01:42 AM
Crank pulley bolt tech4pdx Engine, Exhaust, Transmission 5 03-04-2013 08:18 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
