Old 07-25-2020, 12:43 AM   #1
nicholaswhj
nicholaswhj's Avatar
Drives: Toyota 86
Angry Car kept going to safe mode
Hi everyone, Im not sure if any of you faced the similar issue. Was driving and the car went into safe mode and not able to rev 4K and above. If i slowed down, the engine stalled. Initially I thought it was the MAF sensor so I got it changed.
Today it happened again. I went high speed and almost every gear will be between 6K to 7K rpm before i changed gear. After the high speed downhill session, i went slow, the rev just drop and car just wont go. Engine stalled while causing but I did a rolling start. After a few rev, the car back to normal again.
Is it because of throttle body? ECU? Spark coil? Or MAF again?
I need to help from expert here.
Engine shows no sign of error.
nicholaswhj is offline   Reply With Quote
Old 07-25-2020, 12:51 AM   #2
If it is going into limp mode there has to be a code. Have you checked?
Boomerang (07-25-2020), humfrz (07-25-2020), ls1ac (07-25-2020), p1l0t (07-25-2020), sunami88 (07-25-2020)
Old 07-25-2020, 10:40 AM   #3
nicholaswhj
Drives: Toyota 86
Hi, thanks for the reply. Yes. Plugged in OBD and no fault code. In fact there isnt any fault light on the display as well.. Thats why I am so lost.
The Following User Says Thank You to nicholaswhj For This Useful Post:
Tcoat (07-25-2020)
Old 07-25-2020, 01:54 PM   #4
ls1ac
ls1ac's Avatar
What else have you done to the car?
Old 07-25-2020, 02:17 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
It's a slow car therefore by default it's in "safe" mode all the time.. until that is someone messes with the set-up.
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (07-25-2020)
Old 07-25-2020, 03:16 PM   #6
humfrz
Without a code, we would be just guessing. We would still be guessing even with a code.
Sounds like its time to take your car into a shop for a check up.
Old 07-25-2020, 06:39 PM   #7
p1l0t
p1l0t's Avatar
Did you look at the fault history though? Even if the code goes off it still saves some in memory.
humfrz (07-25-2020)
Old 07-25-2020, 08:17 PM   #8
humfrz
Is not! My car is completely stock and about 2 years ago, a Washington State Highway patrolman didn't think it was slow at all - and I got the ticket to prove it -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
dnieves (08-03-2020), JD001 (07-26-2020), JesseG (07-28-2020), p1l0t (07-25-2020)
Old 07-30-2020, 05:26 AM   #9
nicholaswhj
Drives: Toyota 86
The mods all came from Japan directly
1. Exedy stage 1 racing clutch
2. Endless Zeal Function coilover
3. Endless brake pads
So nothing has been done to the car. Still on JDM limiter.
Old 07-30-2020, 05:27 AM   #10
nicholaswhj
Drives: Toyota 86
it's slow if limiter is on. LOL. I can hardly catch even a 3 series at straight. But a different story when it comes to winding road. LOL.
humfrz (07-30-2020)
Old 07-30-2020, 05:28 AM   #11
nicholaswhj
Drives: Toyota 86
Checked. No fault code.
Old 07-30-2020, 05:29 AM   #12
nicholaswhj
Drives: Toyota 86
I think so.
humfrz (07-30-2020)
Old 07-30-2020, 05:30 AM   #13
nicholaswhj
Drives: Toyota 86
on straight yes. Not on winding road.
Old 07-30-2020, 10:35 AM   #14
Without a code to at least start you in the right direction there is zero way anybody can say what your problem is. There are literally a thousand things it could be.
Car is running too cool, safe or not safe? 5150 Engine, Exhaust, Transmission 15 03-31-2019 10:03 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
At least it kept me safe! Mailman1117 Scion FR-S / Toyota 86 GT86 General Forum 22 08-13-2016 07:59 PM
Is it safe to top off with different oil? bizintine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-23-2015 03:50 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
