Drives: 2013 whiteout frs
Is it safe to top off with different oil?
I'm at 3k miles into my last oil change. Im using Mobil1 0w 20 Advanced Fuel Economy. I noticed today that the level on the dip stick is getting low, can I safely top it off with Mobil1 0w 20 Extended Performance oil? Is there even a significant difference in the two? I just want to save a few bucks cause I already have some laying around..
Drives: 2013 frs
Yes you can, more importantly I'd be looking into your oil consumption issues.
[insert cool phrase here]
Drives: BRZ Premium
Yes you can. As long as it's the same weight, or even close to it, your car will be fine. Hell, you can even mix brands.
Having any kind of oil is better than having no oil.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Oil consumption isn't always an indicator of a serious problem. How much consumption and how quickly it's being consumed is more telling of a potential problem.
You should be fine topping it off with a different type or brand, but make sure it's the same weight. |
Sweet thanks for your input guys. I should mention that I am running e85 with an OFT tune. Might have something to do with the oil consumption but not sure. Either way, it is minimal so I'm not worried.
hmmmm........I'll say, that it won't hurt the engine to "top it off" with any brand or weight of motor oil .....
![]() ![]() humfrz |
Slow Learner
Drives: 15 Halo FRS
In simplistic terms changing brands of oil that have the same viscosity ratings and specifications is the equivalent of buying your fuel at different gas stations and filling up when your at a half tank.
With that said, I don't do it with my cars engines just simply to save a couple of bucks or to use up that half quart left over from a previous change. If I were in a desperate situation and had no alternative I would in a heartbeat because any oil is better than no oil. What I do is compile all my miscellaneous leftover oils into one container and when I do the once a year change on the lawn mower and generator I use that generic mix for those engines instead. |
#8 | |
Drives: 2013 Brz C38 (bought not built :P)
Both oils pass ASTM D6922:
Significance and Use 5.1 It is important that engine oils from different manufacturers be homogeneous and miscible with each other, because operators of automotive engines often do not have prior knowledge of the manufacturer of the oil that is currently used in their application, and engine failure can occur if oils are combined that do not stay homogeneous and function properly. http://www.astm.org/Standards/D6922.htm Discussion: http://www.bobistheoilguy.com/forums...ted_ASTM_D6922 |
| Safe to run 5w-30 oil? | NON-VTEC | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 47 | 03-12-2017 12:01 AM |
| Safe to use DOT 5.1? | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-27-2015 03:32 AM |
| Be Safe | ButeraFRS | CANADA | 37 | 10-12-2015 09:02 AM |
| Is this safe? | Anomie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-25-2014 10:58 AM |
| Are these safe? | mrlewistan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 03-22-2013 04:22 PM |
