Old 07-18-2020, 10:03 PM   #1
solidsnake11
Drives: brz
Ecutek how to get sd to work
Sd blend stays at 0 I have the blend map set to all zeros
sd flags goes from 12 to 15
I only have the maf gs trigger set to 400 , 390
other trigger are zeroed
solidsnake11 is offline   Reply With Quote
Old 07-18-2020, 10:38 PM   #2
steve99
remove all the triggers
Just use SD blend zero all the triggers
see if it works no ral need for trigfers as the sd blend works of manifold pressure once it gets to positive pressure ie over 1 bar jusr set SD
the trigfers often work as a value and a hysterisis
eg the load trigger you set say 0.7 load with hysteresis of say 0.1
im guessing the maf g/s trigger some same way so if you set 400 and 390 its not going to work well
solidsnake11 (07-18-2020)
Old 07-18-2020, 11:49 PM   #3
solidsnake11
Drives: brz
Will do.
Thanks
How do I know that it is using sd?
Ecutek gave a trigger example of 5000 , 4950 rpm
Old 07-19-2020, 06:10 AM   #4
tomm.brz
Drives: brz 2017 hksv2
log sd real maf, sd final maf and the other one, something like sd corrected maf
with full sd, final maf will be same as sd corrected maf
remove all the triggers like stevy said and just use the blend table and remember to enable SD, it s a separate table to check
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
solidsnake11 (07-19-2020), steve99 (07-20-2020)
ecutek inside of KVM: A story of how "not supported" doesnt mean it wont work Breadman DIY (Do-It-Yourself) Guides 6 05-17-2018 08:41 PM
Ecutek Lauch...., cancel they work great Hati59 Software Tuning 2 07-10-2014 06:43 AM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
china ecu cable work with ecutek? garfull Engine, Exhaust, Transmission 1 06-07-2013 01:25 AM
