Old 07-08-2014, 09:54 AM   #1
Hati59
Drives: I no longer own a GT86
Red face Ecutek Lauch...., cancel they work great
Hi all!
Does anyone have a idea of ​​what can be attributed to that Racerom launch control and auto blip work?
I have 3 different versions of Racerom I have tried all of the re-flash, the battery's negative shoe was a half-hour, disconnected and then re-flash does not work.
Ecutek software completely re-installed and updated to laptop, doesntWork.
Otherwise, Racerom works ok. all four different settings can be found, but nowhere in the launch control and auto blip work.
Which one of us is a trouble magnet, me or the car, or are we both hmmm ...
To cancel the entire issue, all are in good condition and working.
I am, and the car is not trouble magnet.
Only I'm sore foot idiot who does not 'kick the gas quickly enough to the bottom.
Hati59 is offline   Reply With Quote
Old 07-09-2014, 08:20 PM   #2
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have found this to be a problem with a few of our customers. In order for this to work you need to have the throttle perform its adaptation after you reset the ECU. Here is the process and this allows everything to work properly.
1. Reflash your ECU and follow all the steps.
2. Now start the car and DO NOT TOUCH the throttle pedal for about 2 minutes.
3. Shut the car off.
4. Now turn the car back on and everything should work properly.
If they are still not working then the tune might have been setup incorrectly.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Hati59 (07-10-2014)
Old 07-10-2014, 06:43 AM   #3
Hati59
Cheers,
William Knose
Okay. Thank you!
Points you mentioned, I probably did wrong each time, until the last new flash after the car became so long that the idle speed dropped to normal, and then turn off the engine.
I do not know, maybe another mistake that I have done in the past when I tested the lauch control, that I pressed the accelerator pedal sufficiently quickly and fully.
Now everything is working great, however, and the latest Racerom give a lot more power, especially in the lower speed is a significant difference
The Following User Says Thank You to Hati59 For This Useful Post:
DeliciousTuning (07-10-2014)
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
ECUTEK Launch Control for AT transmission Kinaa Software Tuning 10 12-22-2013 01:45 AM
ECUTek Launch Control in Automatic 01s0uljah Software Tuning 2 08-12-2013 08:45 PM
ECUTek Autoblip & Launch-control features review? mit_peid Software Tuning 10 07-28-2013 05:05 PM
Ecutek Launch Control test video NoFear99 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-25-2013 08:53 PM
