Old 06-24-2020, 04:05 PM   #1
gt7877
Drives: turbo frs
grimmspeed ebcs brz install????
Dear all
I need good setup
For grimmspeed EBCS
WITH EXTERNAL WATEGATE
WITH BOOST GAGE
car tuned by ecuTek
What your recommendation for
Port 1.2.3
And where I have to put the T for boost gage
Thanks
gt7877 is offline   Reply With Quote
Old 06-24-2020, 04:26 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I put the T for the boost gauge before the bump in the line ( T goes on the engine side) going to the brake booster.
These can be confusing, but I have mine set up so the port on the FRONT is going to the compressor housing, the port on the left (EBCS oriented with the front port facing you and the ports on the bottom half) connected to the wastegate. 3rd port ( on the right) has a muffler on it.
Mine is NOT a branded Grimmspeed EBCS< it is a Mac 3 port valve
The Following User Says Thank You to DarkPira7e For This Useful Post:
gt7877 (06-24-2020)
Old 06-24-2020, 04:28 PM   #3
gt7877
Drives: turbo frs
Can you please explain with diagram or image
Old 06-24-2020, 04:36 PM   #4
DarkPira7e
DarkPira7e's Avatar
WG - WASTEGATE
T - Turbo compressor housing.
I don't have a photo of where I tapped for boost gauge. Start at the brake booster and work your way down the vacuum line. 4" in you'll feel a hard piece. 1" after that is where I put a T
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
gt7877 (06-24-2020), NoHaveMSG (06-24-2020)
Old 06-24-2020, 05:20 PM   #5
DarkPira7e
DarkPira7e's Avatar
Just got done work. Here's one fresh from the garage. Be sure if you use a T to try and get a tapered T fitting.
gt7877 (06-24-2020)
EBCS options wise345 Forced Induction 4 12-02-2016 05:21 PM
Grimmspeed EBCS TheLaughingMan Forced Induction 9 08-05-2016 09:39 PM
Grimmspeed EBCS lbroskee Engine, Exhaust, Bolt-Ons 1 05-06-2016 07:10 PM
EBCS set up options Brick Software Tuning 17 04-13-2014 06:48 PM
EBCS vs MBC gdrider77 Forced Induction 17 02-05-2014 10:30 AM
