Old 04-08-2016, 12:27 AM   #1
TheLaughingMan
TheLaughingMan's Avatar
Grimmspeed EBCS
Searched around but couldnt find specifics.
I know the EBCS plugs into the blue solonoid plug at the bottom, driver side of the intake manifold and how to do the tubing. My question is that my tuner recommended I remove some of the old solonoid to extend the wires so i could mount the EBCS closer to the turbo (greater accuracy).
Just wondering where other people have the EBCSes mounted? How close to the turbo? Will it really make that much of a difference?
It seems like to extend the cable Id have to remove the intake manifold completely...which is a huge PITA. Is there a cable I can buy that can extend the connection?
This E85 upgrade project has me
TheLaughingMan is offline   Reply With Quote
Old 04-08-2016, 03:37 AM   #2
FRS Justin
Drives: 2013 Asphalt FRS
Its 6 bolts to remove the intake I can have it off in 15 minutes. The drivers side has a plastic wire loom that has to be opened and the wires will slip off the intake flange. Its tight but doable. The passenger side, use a long extension and snake it thru the wires to get the back bolt. The rest is straight forward, also while your there put spring clamps on all the hoses you will be glad you did because under boost they will blow off.... I removed the solenoid valve under the intake it's just one nut and its out of the way. Good luck it not that bad of a job just take your time and enjoy.....
EDIT
Option 2
Cut and extend the wires on the EBCS and plug it in. Spencer Fabrication in NH makes a bad ass vacuum block that has several ports get one and you job just became 20 minutes. Plus you can run braided stainless lines..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 04-08-2016, 10:09 AM   #3
TheLaughingMan
Thanks for the reply! Definitely like Option 2 as backup plan but it sounds like a better idea to remove the solonoid and deal with those clamps now.
One removing the manifold... how the hell do I remove this plug!? It's the injector harness plug I think (not the plugs that go to the injectors themselves, but the one that is clipped to the top of the fuel rail)
Old 04-08-2016, 11:23 AM   #4
FRS Justin
Squeeze the sides and wiggle it off. Sometimes it helps to push in then squeeze
710whp
Old 04-12-2016, 10:56 AM   #5
TheLaughingMan
So I managed to get the evap solenoid off and repurposed the vacuum line to be the "port 1" in this picture.
However, I'm wondering if I have created a vacuum leak in the process. I flashed a tune, which, admittedly is a calibration map so not really meant to run great...but I'm having a bit of a surging idle (bounces back and forth between 1000 and 1500). I also noticed on my AEM boost gauge/failsafe that my vacuum pressure is about half of what I *THINK* it used to be. It used to hang out around -30 and now it's at about -15. Could be nothing since I could just completely be remembering that wrong.
What I'm wondering is the evap fuel line itself, that to solenoid connected up to...could that be causing a vacuum leak if uncapped?
I'm talking about this guy circled in red
(ignore the yellow arrow as this is just someone else's picture I repurposed)
Old 04-13-2016, 08:09 AM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
My failsafe gauge reports -19 at idle. Warm-ups it's like -14. Full boost its a steady 8 psi WOT. I'm using a 7psi wastegate spring at sea level.
I found every unclamped hose coming from the intake including the intake to crank case will boost or vacuum leak. Clamp everything!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
TheLaughingMan (04-13-2016)
Old 04-13-2016, 10:40 AM   #7
TheLaughingMan
Well, for anyone who finds this in the future I hope this helps!
I searched and searched for what seemed like a vacuum leak (surging idle, car would die with any amount of throttle). I happened to get a code thrown, P1235 (high pressure fuel pump circuit) which ended up leading me to the solution.
Since I was mainly just seeing if I could get the car to run I hadn't put everything all the way back together yet (strut braces, fuel rail covers, etc.) just in case I had to fix something else. Turns out, if you don't have the DI Driver (the black box on the passenger side that has four cables running into it), mounted on the engine block, it won't be grounded (via the bolts) and your car will run like shit.
Once I bolted even just the bottom bolt of that DI driver back on, it started up and idled fine.
Old 04-14-2016, 07:28 AM   #8
GsxrMe
GsxrMe's Avatar
If you don't have clearance to install the injectors cover on the DI ECU side, I'd cut it so the ECU has 2 bolt locations and not just the engine blocks 1.
I can post a picture of cut bracket if requested.
Finish putting your car back together before driving it!
2014 Subaru BRZ
TheLaughingMan (04-15-2016)
Old 04-15-2016, 10:32 AM   #9
TheLaughingMan
It seemed to mount just fine. I am just using the stock fuel rail and ID1000s though.
Old 08-05-2016, 09:39 PM   #10
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Where does port one go exactly?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Delicious Tuning EBCS blueap2 Forced Induction 4 06-03-2015 08:35 PM
EBCS set up options Brick Software Tuning 17 04-13-2014 06:48 PM
EBCS vs MBC gdrider77 Forced Induction 17 02-05-2014 10:30 AM
Ecutek boost control with ebcs help. gdrider77 Software Tuning 11 02-02-2014 09:06 PM
(SOLD!) Tactrix Subaru EBCS with extended Harness Sportsguy83 Engine, Exhaust, Bolt-Ons 18 09-16-2013 09:21 AM
